Internally regulated alternator used with external voltage regulator
Old May 14, 2018 | 06:45 AM
Chris Cutty's Avatar
I was wondering if you could use both an internal regulated alternator with the existing external voltage regulator? There is an adaptor connector that plugs into the 10dn then the other end plugsi nto the 10si terminal on the alternator. Would a hook up like this causes problems?
Old May 14, 2018 | 06:49 AM
Why would you? It would be a bit redundant.
Old May 14, 2018 | 07:10 AM
Tedd Thompson's Avatar
Just about twice the chance for something to wrong. I'm not sure it would even work.... Tedd
Old May 14, 2018 | 08:06 AM
It won't work. Don't do it. The external regulator needs connections to the alternator that are different from those on an internal regulator unit. The purpose of the adapter cable is to allow you to plug in an internal regulator alternator without butchering your original harness. To do so, you need to jumper the terminals in the external regulator connector. If you want the optics of an external regulator on the firewall, you can simply jumper the terminals inside an old regulator and plug it back into the harness when using an internal reg alternator.
Old May 17, 2018 | 02:39 PM
Thanks so much for the wisdom guys. That's a great idea to jump the wires inside the old regulator . I'll have to see about getting a nice AC Delco cover
Old May 17, 2018 | 03:02 PM
Tom442's Avatar
Link to Oldsmobile FAQ Alternator conversion.
https://oldsjunction.classicoldsmobi...r%20Conversion
Old May 17, 2018 | 04:21 PM
777stickman's Avatar
https://www.lectriclimited.com/
https://www.lectriclimited.com/conve...-harness-85000
Check these sites. I put the SI Alt and this conversion kit in my '65 442 4 years ago with out issue.
Old May 23, 2018 | 08:23 AM
just did the conversion today and it solved my red gen light issue as well thank you
Old May 23, 2018 | 03:28 PM
Glad it worked out for you..............777
Old May 31, 2018 | 11:02 AM
Ugh so I had a senior moment and left my headlights on. Battery is dead put in a new one. Now the GEN light is back on. Why would this be if I have new battery, new alternator with internal regulated conversion kit?
Old May 31, 2018 | 04:17 PM
Check Alt output at the batt with a digital volt meter. Should be around 13.8v-14.2v at 1000 rpm.
Old May 31, 2018 | 05:43 PM
dc2x4drvr's Avatar
WAG, there is voltage feed back, check your wiring, might need an inline diode on the GEN light wire.
72GoldOlds350
Sep 5, 2018 12:35 PM
Cstoliker
Jun 20, 2018 05:14 PM
Dbechtel71
Oct 3, 2014 05:13 AM
ls442
Jul 26, 2012 09:56 PM
D Appeldorn
Apr 1, 2011 11:25 PM
