Interior plastic paint
Old Aug 22, 2017 | 08:07 PM
Zr1bandit's Avatar
What are the options for painting interior plastic parts such as seat backs and center consoles in black color. Anyone have a preference to the best product to use ?? Thanks. Greg
Old Aug 22, 2017 | 08:18 PM
redoldsman's Avatar
Proud Viet Nam Veteran
If it is hard plastic I would recommend Krylon for plastic. Hobby Lobby carries it.
Old Aug 22, 2017 | 08:25 PM
ELY442's Avatar
www.semproducts.com
Old Aug 22, 2017 | 08:40 PM
steverw's Avatar
I used Krylon Semi Flat black on my console in my Olds, looks great. I also used it on my dash in my 65 Vette at the suggestion of John at Redline Gauge in Humbolt, Tn. who rebuilt the gauges 13 years ago.
I dont think its as shiney as semi gloss and its more shiny than satin. Its really nice.
Old Aug 23, 2017 | 04:21 AM
Zr1bandit's Avatar
Any problem with the paint flaking off ???
Old Aug 23, 2017 | 05:29 AM
redoldsman's Avatar
As with any paint job, preparation is the key. Clean it with a good degreaser like Simple Green and then wipe it down lightly with lacquer thinner.
Old Aug 23, 2017 | 06:52 AM
442Fred's Avatar
I use SEM products landau black it is a vinyl dye not a paint product. The vinyl dye bonds with plastic and I have never had any problems with it flaking off even with minimal prep.
Old Aug 23, 2017 | 09:11 AM
Definitely use SEM products, and as noted above, prep is key. First you need to thoroughly clean the plastic, using a stiff brush to scour the grain of the plastic. They, use the adhesion promoter. This product etches the plastic to ensure a good bond. Then spray the color. SEM has detailed application instructions.
Old Aug 23, 2017 | 04:51 PM
CRUZN 66's Avatar
Olds Fever
SEM products would be my recommendation as well... I have used them many times with great results...
Old Oct 18, 2018 | 02:37 PM
shockrebuild's Avatar
I know this is a older post but does anybody like SEM offer a 1970 Cutlass light blue color to paint plastics?
Old Oct 18, 2018 | 08:56 PM
FStanley's Avatar
COlorBond 119 Ford Black
Try it ColorBond 119 Ford Black
available from Eastwood and Amazon
use Kleanstrip BullDog Adhesion Promoter before
You'll never go back!
Old Oct 18, 2018 | 09:07 PM
dream66's Avatar
Cory
Technically...Not a dye. SEM changed their label several years ago because their products are actually PAINTS for plastics.
Adhesion promoters soften the surface of the plastic to PROMOTE adhesion of the top coat paint.
Old Oct 18, 2018 | 09:11 PM
dream66's Avatar
Cory
Urethane basecaot paint with special UV catalysts and Flex additives work great and can be blended to the color of your choosing. You need an HVLP gun and compressor. There are acceptable inexpensive HVLP guns if you don't have one.
p.s. FWIW - I don't object to bringing up older threads.
Old Oct 19, 2018 | 08:30 AM
oddball's Avatar
Year One has a few interior colors that are OK. You may want to test them out. Those were the best I could find off the shelf when I started looking back in .... 2012?
I ended up getting a custom color mixed in PPG DBC at the local jobber shop. The flex additive is only needed on things like seat covers that move a bunch. Normal plastic and vinyl (dash pad, console, seat backs, etc etc) can use straight paint.
Old Oct 19, 2018 | 08:11 PM
vmathy's Avatar
I used the SEM black on my console lid but it is too flat of a finish compared to the rest of the console. I have some eastwood underhood black I am thinking about trying that. My buddy just did his 69 blue hard plastics with some ppg in a spray can that he had mixed to match, it looks fantastic!
Old Oct 22, 2018 | 05:18 AM
oddball's Avatar
Which SEM black?
Old Oct 22, 2018 | 01:06 PM
vmathy's Avatar
I used Landau Black.
Old Oct 22, 2018 | 05:31 PM
Thanks All for the info
Molen
Jul 9, 2016 01:30 PM
Joffroi
Aug 19, 2011 10:23 AM
Lady72nRob71
Sep 25, 2008 05:31 AM
70redvert
May 5, 2008 08:58 AM
awspeich
Feb 23, 2007 12:50 AM
