intake valleypan gasket ?
Old Aug 27, 2011 | 09:20 AM
archerbob's Avatar
I have a 330 engine and am putting a stock intake back on and I'm wondering if I need to use the valley pan gasket or a 4 piece gasket set .The engine has an oil tray bolted onto it.
Old Aug 27, 2011 | 09:23 AM
Does yours have the metal tray in the lifter galley attatched with 2 bolts? If it does then you need the 4 piece set. If not you can use the valley pan.
Old Aug 27, 2011 | 09:47 AM
The 64-66 330 motors used individual metal side gaskets (they look like the ends of the turkey tray gasket) with a separate bolt-on valley tray. You can use the turkey tray for the 67-72 SBO if you leave the bolt-in valley tray out. The newer gasket may be easier to find than the original separate metal gaskets.
Old Aug 27, 2011 | 10:12 AM
archerbob's Avatar
Thanks, the engine has the lifter galley tray. Looks like it would be easier to take it off and get a turkey tray gasket.
Old Aug 27, 2011 | 11:55 AM
They are both readily available at your local autoparts house. The 4 piece is a whole lot easier to work with!!!
Bobac455
Dec 4, 2013 09:23 AM
aussiemobile
Feb 15, 2013 07:31 AM
harry k
Nov 21, 2012 08:54 AM
dallasite21
Jun 20, 2010 05:37 AM
Sixoh
Aug 8, 2006 05:11 AM
