Info Please
Old July 27th, 2011 | 09:43 PM
bonezarally's Avatar
Info Please
what does anyone know about the olds v6 3300?
Old July 28th, 2011 | 09:20 AM
Yeah, it's really a Buick V6. Same family as the 3800. What do you want to know about it? PS, it would help to know the year and model, as there were different series of these V6 motors.
Old July 28th, 2011 | 10:22 AM
93 cutlass cierra s
Old July 28th, 2011 | 01:23 PM
93 cutlass cierra s
I believe that's a Series II motor. The block uses the bellhousing bolt pattern from the 60 degree V6 motors, not the traditional BOP pattern. Heads are different also - equally spaced exhaust ports instead of the earlier asymmetric ports (the old V6 motors had heads that were essentially V8 heads with the end cylinder cut off).
What is your question, specifically?
Old July 28th, 2011 | 01:50 PM
it has 130000+ is it a decent motor that will last for awhile longer?
Old July 28th, 2011 | 02:13 PM
455man's Avatar
I had a 3800 series II last 145000 before I started having problems with it. Depends on how it's treated...
1952SUPER88
May 4th, 2012 07:10 PM
sx455raidercelticfan
August 1st, 2010 09:03 PM
viper771
May 31st, 2010 01:40 PM
Olds Newby
July 10th, 2007 06:46 AM
troys2222
May 2nd, 2007 07:14 AM
