Ignition switch replacement
Old February 28th, 2019, 08:15 AM
67Rocket's Avatar
Have any of you guys ever replaced the ignition switch in your Cutlass? I have a 71 Cutlass that is in locked position with no key, any suggestions? Thanks
67Rocket is offline
Old February 28th, 2019, 02:43 PM
If you lost the keys, either remove the lock set and have a locksmith cut a kit to match, or buy a new lock set. About 20 bucks, it does require some disassembly to replace.
The ignition SWITCH (which has nothing to do with the ignition key) is on top of the column, basically under the speedometer. It’s purpose is to direct power to the various circuits depending on the key position. Replacing the switch requires dropping the column to access it.
matt69olds is offline
Old February 28th, 2019, 03:03 PM
On a 71, the door lock uses the same key as the ignition. It's often easier to remove the door lock. There should be a four character code stamped on the outside of the lock cylinder, which can be decoded to cut a new key. Failing that, you can remove the steering wheel and lock plate to take the ignition lock cylinder out of the column.
joe_padavano is online now
Old February 28th, 2019, 05:39 PM
67Rocket's Avatar
67Rocket is offline
Old February 28th, 2019, 05:44 PM
67Rocket's Avatar
I have a ignition switch from a 71 or 72 Chevelle, are these the same?
67Rocket is offline
Old April 17th, 2019, 10:53 AM
frankr442's Avatar
I work in a parts department. The confusion between switch and cylinder makes me glad I stay at the mechanics counter.
frankr442 is offline
Old October 18th, 2019, 03:21 PM
The spammers are growing. Anyone who is FirstNameLastName like those above are suspect.
Koda is offline
revrory12
October 26th, 2021 08:54 AM
slantflat
March 23rd, 2021 10:33 PM
prohandze
February 22nd, 2016 06:00 AM
fjross
October 26th, 2009 04:24 AM
marlo7488
March 9th, 2008 07:57 PM
Quick Reply: Ignition switch replacement
