Ignition switch replacement
Old Feb 28, 2019 | 08:15 AM
67Rocket's Avatar
Have any of you guys ever replaced the ignition switch in your Cutlass? I have a 71 Cutlass that is in locked position with no key, any suggestions? Thanks
Old Feb 28, 2019 | 02:43 PM
If you lost the keys, either remove the lock set and have a locksmith cut a kit to match, or buy a new lock set. About 20 bucks, it does require some disassembly to replace.
The ignition SWITCH (which has nothing to do with the ignition key) is on top of the column, basically under the speedometer. It’s purpose is to direct power to the various circuits depending on the key position. Replacing the switch requires dropping the column to access it.
Old Feb 28, 2019 | 03:03 PM
On a 71, the door lock uses the same key as the ignition. It's often easier to remove the door lock. There should be a four character code stamped on the outside of the lock cylinder, which can be decoded to cut a new key. Failing that, you can remove the steering wheel and lock plate to take the ignition lock cylinder out of the column.
Old Feb 28, 2019 | 05:39 PM
67Rocket's Avatar
Old Feb 28, 2019 | 05:44 PM
67Rocket's Avatar
I have a ignition switch from a 71 or 72 Chevelle, are these the same?
Old Apr 17, 2019 | 10:53 AM
frankr442's Avatar
I work in a parts department. The confusion between switch and cylinder makes me glad I stay at the mechanics counter.
Old Oct 18, 2019 | 03:21 PM
The spammers are growing. Anyone who is FirstNameLastName like those above are suspect.
revrory12
Oct 26, 2021 08:54 AM
slantflat
Mar 23, 2021 10:33 PM
prohandze
Feb 22, 2016 06:00 AM
fjross
Oct 26, 2009 04:24 AM
marlo7488
Mar 9, 2008 07:57 PM
