ignition issue
ignition issue
Was going to take the car for a ride the other day and I tried to start it but the key would not engage the starter and the key won't come all the way back so I can not get my key out of my ignition.Would that be the cylinder issue or something else
Is the backdrive linkage in place and adjusted properly? If the collar on the steering column has vibrated out of place or is not indexed properly due to misadjusted linkage, it can cause this problem. Of course, so can a bad switch, bad lock cylinder, or binding rack and linkage in the column. The collar is the easiest thing to check first.
My 76 has the same issue other than not starting, I have the buckets with console shifter so I have to turn the collar/column in order to get my key out every time, just as the guys mentioned above.
Eric
Eric
So either the backdrive rod is missing or out of adjustment. That's an easy fix.
I have been turning the column for a few years now it hasn't been that big a deal but I should crawl under the car and have a looksie.
Your knowledge is always welcomed and appreciated here.
Cheers
Eric
chrisneu68olds
June 29th, 2015 03:53 PM
