Idle Stumble
Idle Stumble
Q: On my 98 (1995 3800 series 2 non turbo) it just recently started dropping rpms while stopped in drive to around 650. Normally it would be around 690-700. Occasionally it will drop to around 620 and the car will shudder, but then it picks back up again. Is this a problem with the Mass air flow? Or is there some way to adjust the idle of the engine. The car has 146000 miles, but starts great and still gets great mileage city and highway. Any suggestions?
Sounds like the IAC (Idle Air Control) solenoid may be either getting weak or is carboned up. It is a stepper motor, what it basically does is create a calculated vacumm leak in the throttle body which adjusted the idle speed. You can remove it and clean the end of it, and the passage in the throttle body, that may take care of it.
No, the SE light is not on. There's no vacuum lines to check on the 3800, and tuneup is basically just changing the spark plugs (which were changed only 35,000 miles ago. They should be ok for at least 60,000 according to GM spec). The car starts instantly, and runs exceptionally well during driving, has great top end power and still gets around 20mpg city and 37 mpg highway - if you drive economically. If you want to put your foot into it, it'll still go like a scared bunny.
There are vacuum lines they are plastic but they use rubber ends they do dry rot and cause vacuum leaks. If a MAF sensor goes bad this is what happens you start your engine up the engine idles up to 2500 rpm for about 30 seconds and dies. It does have an idle control motor its on the side of the throttle body I doubt if that's your problem. Here something else for you check battery cable ends clean them up. I have had the same problem with 3800 that's were I with battery cable ends works 99% of the time. The two hot cables going to a single hot post has to be cleaned often.
I had a similar problem when I had my 00 Grand Prix with the same engine. Sometimes the idle would fluctuate and would sometimes start bucking while driving. When sitting at lights with the car in gear, the rpms would rise and sometimes would stall out. It rarely threw a code and when it did, it would be a misfire code. Eventually it started throwing a maf sensor code. Replaced that and the problem went away.
It did start with the fluctuating rpms at idle, then after awhile it started bucking while driving. Maybe that is something to look out for.
Fellow buckeye?
Hey, I just noticed you're in OH. I used to live down in Dayton back in 77- 78. (actually, I lived in a hotel - La Quinta, if I remember right it was just off I 75, while I was working for a computer company and flying back and forth a lot. But who cares, they footed the bill. Even paid for a rental except for personal mileage. I had to log that). North Ridgeville is nothin a cruise up a couple of interstates wouldn't cure!! Do they still drive like maniacs on I 90?
My 96 Pontiac loved batteries. I had to change them about every 3.5 years. Had new cables and I always did keep them clean. But it would act just like what you explained. Some times cleaning would fix it, but about every 3.5 year would have to change battery.
I consider most drivers in Northeast Ohio idiots They seem to think the fast lane is for doing the speed limit, don't know what blind spots are, and they seem to think they are the only one on the road. Don't even get me started about when snow comes
To answer the last question about the shifting, no. The shifting was always fine on the car.
Well I just got done working on my sons 97 GP 3800, his was doing the samething, The IAC had already been replaced, so wasn't that, turned out to be the MAF sensor. Replaced that and it idles like brand new. But his did throw a service engine soon light.
I really don't think many things go wrong with those engines. I seem to hear about the maf sensor a lot, not to mention the intake manifold gaskets, and I have had some ignition problems. I still think that is one of the most bullet proof engines that gm has made.
I also like the 3800 I've owned a few and had to replace a couple one had the rod hanging side of the block. That what happens when right feet is a little heavy. The MAF does go bad it either has a rough idle or you start it up engine idles up than dies that it. If it has a rough idle they make a cleaner for MAF just take it out clean it put it back in.
On the 95 and up the heater bypass tube will leak after time coolant eat at the plastic tube. Most of the time when you change it the end brakes off so you have to take the intake off to get the broke piece out. Most of the ignition problems go back to the ground cable most people change out a lot of parts just find out it the ground cable. One problem they do with the ignition switch is a spring on the side does get weak. That's were the cable from the shifter button goes to the switch. What will happen is go turn off the car the key will not turn to lock pos. and the steering will not lock either. The problem that Allan is having is another problem the 3800 have it's simple in gear the idle drops just a little than back to normal it's either battery needs to be replaced or battery cable that needs to be cleaned or replaced. He said that his is 5 years old. That about the max one last in a car mainly one with a 3800.
I have a 1990 olds 98 touring sedan with 3.8 and the wife loves it!we've had it for over 10 years and is pushing 300kanytime I have had probs with the idle circuit as you are describing I used the G/M top engine cleaner.with engine idleing you spray it into the intake before the MAF and let it kill the engine and then pull the piping that connects the throttle plate to the filter box.then give the throttle butterfly a good spray and wipng with a rag and another another good spraying.reassemble and should be good to go and if not at least you know the upper end is clean
I was thinking it might be the IAC motor as well. This was a common place for carbon to build up on the early to mid 90s cars. Ford had a similar problem, they just called their's an Idle Air Bypass. It is SUPER easy to remove the throttle body and clean the back of the throttle plate and the IAC motor. I think the gasket for the IAC and throttle body is about $8.00 at Auto Zone.
I've never heard about cleaner for a MAF sensor. If you decide to clean the MAF sensor make sure you use the cleaner for it and not brake cleaner. A MAF sensor is essentially a small computer, if you get something on it that is caustic or damaging then you might be out $200 for a MAF sensor.
Long time. Ok I need some info about this IAC motor. Both you and bcracing seem to be on the same page here. Now, where the heck is it on a 3800 series 2 and what does it look like? If you've got a tech manual or pic send it to me on a pm or post it here and I'll print it. Talked to Peter today and he suggested it might be the IAC also, but said to first think about changing the plugs. I've got NGK platinum in it now with only 37000 miles on them, and the car has no problem with acceleration or stumble when driving. He says that GM recommends copper plugs for higher mileage units, and thinks this might be a better way to start troubleshooting. Don't understand this. Do you? Glen suggested I hook it up to an OBD 2 to see if I can get a fault code like a faulty relay. Problem is I don't have an OBD 2 and it's usually about 90 bucks to get one hooked up and read out.
About the MAF? Yeah, you're right. But 200.00 is a little on the light side. They're a little more than that up here. Don't worry, if I clean it, I'll get some electrical parts cleaner and spray it down. Nix on the brake cleaner. From everything Pete says, it's not likely the MAF. Gonna stop by the parts store tommorrow and pick up some NGK copper plugs and a new PCV. I change the PCV about every 5000 miles just to be safe. You wouldn't believe the one I took out when I got the car. It was one solid gummy bear. I'm also going to give a shot of air down the PCV intake to break any crud loose that may be in there. I'm not going to touch the MAF unless I have to. Maybe I can find a good one at the boneyard next time I go out. Usually they sell computer sensor stuff for around 25 bucks or less. Read somewhere to look for a car that was in a crash. More likely to be the cause of being in the boneyard than engine failure.
This car is starting to get to me. Its getting to the point of not knowing what the next thing is that will go wrong. Like the AC that went wonky in the late summer. I'm not fixing it. AC is never cheap to repair. And this car has mostly electronics for AC. I know its not new, but this particular car seems to have been plagued with issues. Built on Monday? It doesn't know how lucky it is that I happen to be an Olds guy. I just tallied up the repair bills over the past 5 years and almost fell out of my socks! More than $12,000.00. Crap! Our vehicle tech just stopped by my office today and asked if I was still interested in his 2002 Lincoln LS. I'm starting to look at what's going to cost less and be more reliable. Man, I just hate having a moneypit. Need to win a lottery here, and soon!
as stated before the GM top engine cleaner is the cleaner to use and is safe for the MAF and can be used to clean the pintle on the IAC also!(best to pull the IACoff and wipe pintle down with the cleaner and spray in the pintle seat and wipe also)on your vehicle the MAF is right on the throttle body that is a black box assembly,approx 2"x3".another thought came to mind to your problem!
have you replaced the battery,or disconected or had a situation that the vehicle needed jump started recently?Not positive about the year you have but I'm pretty sure yours has the idle learn circuit programmed into the computer.in another words the vehicle has to learn it's idle.I worked on these vehicles at the dealership when they were new and dealt with a lot of drieabilality issues.to make sure it's not the computer guessing what it's gonna do--disconnect the battery for a minute or so and reconnect.
then be sure all accessories are off-A/C,radio,heater,etc.set parking brake
start engine and immedietly place shifter in drive without ever touching the throttle and allow to idle in gear for 10 minutes.shift to park and shut off and restart and put right back in drive and let idle 5 minutes again without touching the throttle.at this point the computer should have learned the idle circuit.if you have other probs then you will still have the surging you are referring to.then I will need to know the TPS reading at idle from a scan tool.or there is a way to adjust minimum idle but is used as a option if there is slop in the throttle plate etc.make sure you use the idle learn after you clean as stated in my last post.I will keep an eye on your post here till you get it fixed!any questions just ask.
Throw the ngk plugs in the trash and put ac plugs in have removed more ngk plugs for idle problems in the last 10 years than can count. may not be your problem but why create one. Sounds like idle searching going on its usually caused by a vac leak, spray intake to head area with throttle body cleaner with the motor running, if there is a leak should see a rpm change either increase or smooth out. The only way to pinpoint the mass air flow is with a lab scope or test with a known good sensor. Do believe there is one vac lead from motor to firewall that develops a leak in the rubber part at fire wall tee.
Warm or Cold?
I would stay away from 2002 Ford anything in 02 they had trans problems and bad head gaskets. I work for a part supplier for Ford and shouldn't say it but it's the truth. I like what Meoff said sounds like pretty good advice. The OBO 2 scan tool won't tell you anything unless spend a lot of money on one with all the bells. The cheaper ones are only good with engine light on they can read the code. If the engine light is off sol. Might want to check your belt tensionor it's worth a look. If the spring is weak it's not keeping good tension on the belt at low rpm could have voltage problem that would cause your idle to drop. If your going to buy a Ford go with 05 or newer or 00 and older can't tell why but trust me 01-04 everyday at Ford was a Monday.
Allan, the IAC motor is on the side of the throttle body. The easiest way to find it is trace your throttle cable to the throttle body, then you will see a small component on the side of the throttle body held on by two machine screws with an electrical connector going to it. That is your IAC motor.
IMHO, you should buy the throttle body gasket at the auto parts store and remove the throttle body (4 bolts) and IAC motor (2 machine screws) for a cleaning before trying anything else. I've done this on all of my newer cars with good results. After 100k+ miles the metered orifice in the IAC motor gets filled with carbon and no longer provides good air flow.
MAF, IAC & WTH??
......another thought came to mind to your problem!
Since CO has not been working well lately, I'll bring you up to speed with what's happening. First, I did what you suggested with the idle learn circuit. That had very little effect. One thing I need to clear up b4 going on, the engine is not "surging". It starts well cold and runs at about 1240-1250 rpm until all 6 light bars (electronic dash) on the left side are lit. It then drops to about 810 rpm. In gear it drops to 710 initially, then drops down to 680, then 660 and sometime 650-620. The idle is still relatively smooth, but you can tell that its way too low and the engine is struggling to stay going.
I disconnected the battery completely and checked both terminals and leads. Super clean. Put on some "No corrode" and tightend the leads back up. Started the car (warm) and in drive with park brake on for 10 minutes. Engine off. Restart and followed you load suggestions with AC. Not much improvement. I read on the web that the GM IAC resets if you turn the key to the "run" position for 20 seconds, then "off" for 10 seconds, followed by a restart. Then they say to run the car through 5 cycles of varying rpms up to 3500 to let the ECM monitor and learn.
Anyway, at this point in time I'm about to try cleaning or replacing the IAC. The parts store says $52.00 for a new one. From what I've read, my IAC could be working, but carboned up and not getting proper signals from the ECM to regulate properly at low idle when accesories are kicking in.
I took a picture of my engine and labeled what I think are the MAF, IAC and something I have no clue about (I call it WTH). Is my label right? I'm so tempted just to replace the unit because the car has over 270,000 km on it. (169,000 miles) That's a lot of wear on an electrical motor.
Is this pic right?
IMG_1157-1-1.jpg?t=1258262746
Hope you can log on to get this. Anyone else who knows if it's labelled right let me know asap. I'd like to have this up and running by Sunday afternoon. Thanks for your help
The MAF and IAC are correct. The other is the TPS throttle position sensor. I was going over my notes and some time ago. I had fix a car that had a problem with the IAC. The O-ring failed on it. I took it out and cleaned the IAC and replaced the O-ring. That were the notes ended so I guess that fixed it. I didn't remember working on that one.
70 Cutlass S is correct. The IAC and MAF are labeled correctly, the other component is the TPS. It seems that the nut directly above the IAC motor is one of the nuts that holds the throttle body on the upper intake manifold. Go ahead and take off the throttle body and clean it thoroughly. While you have it on the bench you can remove the IAC motor and MAF sensor and clean them as well.
On the down side to getting this done, just after I got back from the parts store and gas fill up for the wifes car, one of the garage door springs busted! Heard it from inside the house it was that loud. Worst part is that I don't have winders to release the tension on the other side spring. Also the lift wire derailed off its pulley and won't let me lift the door even with the traveller disengaged. Door repair company said they would do an emergency call for min 2 hours overtime, just to get the car out of the garage, not to fixit. Screw that. I'm going to have to take tommorrow off so I can get the springs and a set of winders. So my IAC project will be put on hold until at least tommorrow or Tuesday. The wife can use my Olds until we can get her car out. I'll have to take the bus and train again.
Bummer to hear that your garage door broke. I would be hot if mine broke! We had a new one installed in February. Good luck with that.
The IAC pintle seat gets dirty because it is a metered orifice that regulates a vacuum leak at idle. Whenever you shut off the car the engine is still hot and the burned carbon goest up the intake manifold and causes carbon to collect on the back side of the throttle plate and in the metered orifice of the IAC pintle seat.
You can easily clean it with an old toothbrush and carburetor cleaner. Definitely use eletrical cleaner on the connectors going to the IAC.
Part 1
Anyway, he shows up at 3:10 and looks over the problem. "So it won't open?" he asks. I felt like handing him his sign, but instead I politely said, "Oh sure it opens, I just get terribly lonely and enjoy having guys drop by for a beer once in a while". He looks at me. "Of course it doesn't open" I say. "Why do you think I called you? And, one more thing" I added "You put any scratches or dents in that Oldsmobile and you're not getting paid".
Long story short: This guy finally solves the riddle and gets the door fixed. 2 springs replaced, new steel rollers and adjustment to the eyes and door sensitivity and it's back in business. "How do you want to pay?" he asks. With a straight face I tell him, "Well seeing as how you used some of my tools and you were really late, I don't really want to pay at all". He looks at me like I have leperousy, and just stands there for a minute. So I let him off the hook. "I'll use my VISA, ok?". So he goes to his truck and writes out the invoice. Brings it back to me about 10 minutes later. $482.33 I look at him, then the invoice, then him again. "So tell me" I say, "just how many shares of your company am I buying here?". I don't think he understood, so I just signed on the line. Took him almost 2 hours to do the job, but he only charged for 1 hour. I wasn't expecting a whopper of a bill. Figured it might run 250 or so, but not this much. What can you do? When you're bent over a barrell, the only thing that makes you smile is that sooner or later it's gotta stop....
Well it works, the wife isn't stranded, my boss hates me....... All is good in the world again.....
#31
Part 2
I'd like to thank all you guys for the great support and coaching on this project. The next step is to see whether the idle learn circuit will work properly with this new IAC, or whether I need a new ECM. Anyone got any thoughts on that?
#32
Went to NAPA this morning and got a TB gasket. You were right. $8.09 Didn't know they were neoprene? Anyway when I get home tonight I'm going to see if I can get the TB off and clean it up. Read somewhere else on the web that sometimes the carbon deposits are fairly hard and have to be "dissolved" or chipped away until the IAC passage is open. Will also clean the TB blade up nice and make sure it has free movement. I'll try to take some b4 and after pics.
Also, (meoff) a can of GM Top Cleaner - $18.99 from a Chev dealer closing out next month. I'll use it after I do the TB cleaning. As you said, it doesn't hurt to have a clean top end.
Later.
#33
Good luck Allan. I don't think you will have a problem removing the TB. I just hope it works for you. I usually use carburetor cleaner and an old toothbrush to clean the TB thoroughly. Keep us posted.
#34
Now when I was taking off the 2 rubber (really brittle rubber I might add) connections by the TPS, I noticed that the lower one was cracked down the middle. Ah ha! I thought, You're the little bugger that's been sucking extra air and causing my IAC to malfunction. But, since I was this far along, WTH, keep going and take off the TB. It looked ugly. See for yourself.
IMG_1164.jpg?t=1259116395
Although it looked like it operated smoothly in wide open....
IMG_1166.jpg?t=1259116460
Opened up a fresh can of TB cleaner and got my toothbrush out. After about 10 or 15 minutes, it looked like this....
IMG_1168.jpg?t=1259116557
IMG_1169.jpg?t=1259116584
The TB gasket was in almost new condition, but it got replaced anyway. $8.00 is not worth chintzing out on for a clean running car. Inside the upper intake looked a lot like the b4 pics of the TB, so I'm going to use the GM Upper end cleaner on it. Can't hurt.
Doesn't look like much does it? Here's what washed off into the cardboard tray I used.
IMG_1171.jpg?t=1259122485
So now I'm ready to put this puppy back together. Reverse the process and it's done like dishes, right? Don't know if this will work, but that cracked fitting is likely going to suck air again, so before I put it back on, I wrapped electrical tape ALL around and tried for a temporay seal. Put a dab of KY on the boot to help it over the fitting. Heck maybe it'll seal better too. Fire that puppy up and lets see what happens.
Heavy sigh..........Still the same old. So I thought, try an IAC reset. Son of a gun. It's idling around 810 in park. Put it in drive and it's steady at 750. Yea!!!!! for 30 seconds. Then it drops to 710, 700, 690, 680, and levels off at 650. This crap is starting to get to me. So I shut off the car, restarted it and put every draw item I could think of on: AC, lights, rear defog, fans, radio and put it in drive. Wanted to see if it would die. Then all my suffering would be over. No way Jose!!! In park it pegged itself at 680 and didn't budge, even with all that load. In Park, it ran at 720-730 .
Now I need all you guys with the experience to wisen me up. That boot that is cracked is the lower one in the pic It currently has about 4 winds of electrical tape around it. If you look at the pic, that book also has a lead that goes to a sensor on the top of the intake manifold. Don't know what its for though. Tommorrow I'm going to the wrecker to find the 2 rubber boots for the connections by the TPS. If they are the problem, wahoo! If not I'm going to need another boost from you guys ok?
Here's my next try at fixing. Tried to show it in this pic.
IMG_1157-2.jpg?t=1259122295
#35
BUMMER!
Sorry that didn't help your problem Allan. Definitely replace those rubber boots if they are cracked. It is difficult to determine what those rubber boots are for from the picture. Where do the hoses lead that come off of the rubber boots?
BTW, have you checked for vacuum leaks? You mentioned that the idle drops only when it is in drive and the car is stopped, it makes me wonder if you could be getting a bad manifold air pressure reading because of a vacuum leak or faulty sensor.
#36
BUMMER!
Jesse, one question. Wouldn't a vacuum leak result in a higher idle instead of lower?
Those boots? They attach to 2 metal lines that go ????somewhere I'm not crawling under to find out. One of them (the lower one) goes to a sensor on the intake. The intake manifold was just done a year and a half ago, so I don't think that's the problem. Gotta look at the backside of the engine to see if there's any other brittle lines. I'll see what I can find. Also gotta rememeber to take some non perishable food to the wrecker. They''ll let ya in for free if you do cause they're helping the local food bank this week. Good deal all the way around. Later>....If I see any land yachts I'll let you know...
#37
Just got back from the wreckers. Holy Hanna! Out of all those cars no compatible parts. I did take a couple of rubber boots, but couldn't remember exactly how they lined up. Not really a problem they were no charge items. The 3800 series 2 engine seems to have been modified for Buick and Pontiac. There were about 4 99-02 Lesabres and Grand prix's but the TPS area only has 1 outlet. The other one has been blocked off. Don't know why??? The boots for the later model 3800s come straight out of the TB, which is ok, but both of mine bend 90 degrees so they will line up with steel lines (which I don't want to bend). I found a couple of Delta LSSs but they have 2 tees on top of the TB, not like mine. I just love how consistent GM is.Sooner or later, a 95 or 96 98 hqw to come in, and I'll be on it like a fly on *****.
#39
The vacuum ends "boots" one goes to the trans. and the one that has two lines goes to the purge valve and goes to the fuel regulator on the fuel rail so if you lost vacuum with that one your idle could be affected. The only place you can buy new one's is at the dealer.
#40
Purge valve or Fuel reg?
IMG_1181-1.jpg?t=1259283441
When I took this picture, I also noticed some other rubber hoses on the left side of the motor (close to the vacuum line for the brake booster). They all seemed very pliable, but maybe I'll replace them on general principle.
Ok, in simple terms, explain to me how the vacuum leak will affect the idle. I thought that a vacuum leak will result in a higher idle?
