Idle is low while in drive, advice sought
Old Feb 20, 2017 | 07:45 PM
Bryan Burch's Avatar
Question Idle is low while in drive, advice sought
Any advice on what I could adjust? I've ran the idle screw where it is at about 1150 rpm in park, but when I put it in drive it nearly kills the car. Really low, like enough to make the dummy lights come on.
1969 442, th400, 455ci, edelbrock performer intake and edelbrock 750 (1407 with the electric choke add-on).
Thanks in advance!
Old Feb 20, 2017 | 08:12 PM
svnt442's Avatar
Where is the initial timing set and what distributor are you running?
Old Feb 20, 2017 | 08:46 PM
That's a great question about the timing and distributor. Looking at the receipts from the previous owner, it's an Autoline D243. Pic at amazon: http://a.co/fdgy7nQ
I can buy/borrow a timing light, but I have a note from a shop saying the timing mark on the harmonic balancer isn't right. So I guess I'll start with finding TDC and work from there.
Old Feb 21, 2017 | 04:58 AM
Double check the mechanics note about the mark, make sure the harmonic balancer hasn't spun. If it has you'll need to replace it and go from there.
1976Cutlass
Mar 8, 2016 01:41 PM
VI Cutty
19
Nov 22, 2015 04:04 PM
5998DownUnder
Dec 27, 2013 09:12 PM
Herv Purcell
Aug 10, 2011 08:41 AM
Red Delta
Oct 25, 2009 05:03 AM
