Ididit Steering Column
I see tilt fs columns on ebay quite often, expect 500.00 price range.
Interchange
64-66 Buick Special Skylarks
64-66 Pontiac Tempest Lemans
64-66 Oldsmobile f85 Cutlass
64 and 65 Chevelle(66 not the same)
Henry
Interchange
Henry
I don't know how close the aftermarket columns are to original, or how much work is required to install one. I do know that even their columns for older cars use the larger diameter upper end from the 1969-up cars, so your original steering wheel won't work. Also, verify what turn signal switch they use, as I suspect it is also from the newer cars. That may require some rewiring or at least an adapter harness.
ros6872
Mar 28, 2014 09:48 AM
c-towndave
Suspension & Handling
Oct 21, 2013 07:41 AM
