Ididit Steering Column
Old Jul 25, 2014 | 10:40 PM
66 Olznut's Avatar
Ca's Only Official OLZNUT
Has anyone used these? I have a '66 and was thinking about putting one in. How hard is it to find an original floor shift tilt column for it?
Old Jul 26, 2014 | 06:16 AM
I would think that the Ididit would be a snap, there are plenty of A bodies using them. On the flip side a floor shift column probably can be had from one of the members on here.
Old Jul 26, 2014 | 06:33 AM
66400's Avatar
I see tilt fs columns on ebay quite often, expect 500.00 price range.
Interchange
64-66 Buick Special Skylarks
64-66 Pontiac Tempest Lemans
64-66 Oldsmobile f85 Cutlass
64 and 65 Chevelle(66 not the same)
Henry
Old Jul 26, 2014 | 06:59 AM
I don't know how close the aftermarket columns are to original, or how much work is required to install one. I do know that even their columns for older cars use the larger diameter upper end from the 1969-up cars, so your original steering wheel won't work. Also, verify what turn signal switch they use, as I suspect it is also from the newer cars. That may require some rewiring or at least an adapter harness.
starfire
Dec 9, 2021 08:21 PM
317Cutty
Jun 18, 2014 10:53 AM
ros6872
Mar 28, 2014 09:48 AM
oddball
Mar 4, 2014 06:42 AM
c-towndave
Suspension & Handling
Oct 21, 2013 07:41 AM
