Ideas for customizing 1964 C10 with Olds 455
Old Mar 4, 2020 | 05:34 PM
jpayne_80@hotmail.com's Avatar
I have an Olds 455 (468 after boring 60 over) in my 1964 Chevy C10. I would like to some how "advertise" or represent my Olds engine on my C10, but I'm not sure what to do. Is there some type of emblem you'd recommend to place under the C10 emblem? Or?
I'm not wanting something gaudy but maybe something that would pique one's interest.
Currently my pickup is white, but once I weld in the last couple of patch panels it will be painted matte gray/charcoal.
Thanks!
Old Mar 4, 2020 | 07:31 PM
svnt442's Avatar
Well Olds never put engine size on their vehicles soo.....You could always try and incorporate a rocket logo somehow.
Old Mar 4, 2020 | 07:37 PM
Sugar Bear's Avatar
How about an Olds Rocket replacing a bowtie or...a very small graphic of an Olds Rocket dropping a bowtie like a rocket drops it's boosters?
Old Mar 4, 2020 | 07:41 PM
You can always paint Rocket Powered on the tailgate, stencil something on the rear window, or something along those lines.
Old Mar 5, 2020 | 01:09 AM
OLDSter Ralph's Avatar
^---^ and an early tri-colored 442 emblem under the C10
Old Mar 5, 2020 | 06:16 AM
Weezer's Avatar
Jeff
If the 455 is built with any W30 components, then I would enthusiastically recommend W30 badges under the C10 (or even in place of them).
Old Mar 5, 2020 | 07:21 AM
Sugar Bear's Avatar
Drawing from Weezer's suggestion, it could be badged a W10. That should raise some questions.
Old Mar 5, 2020 | 07:32 AM
cherokeepeople's Avatar
some buick's used a 455 emblem.
Old Mar 5, 2020 | 08:09 AM
70cutty's Avatar
Beer Connoisseur
Put a neon sign on the back window, that will advertise it.
Old Mar 5, 2020 | 08:28 AM
I don't know about the rest of you, but I'm not a fan of putting an Olds motor in a Chevrolet, just like I'm not a fan of the reverse.
If it has to be done, I'd rebadge the truck as a GMC and put a Powered By Olds underneath it.
Old Mar 5, 2020 | 10:51 AM
Weezer's Avatar
Jeff
That's even more clever, and I like it better than my idea.
Old Mar 5, 2020 | 04:00 PM
w-30dreamin's Avatar
71 & 72,now I want a 68
A functioning 69 cutlass marker light would be cool,but they are not flat on the bottom side.
Some omegas had smaller square rocket emblems.
Old Mar 5, 2020 | 04:39 PM
Sugar Bear's Avatar
W10 below a rocket emblem backlit in bowtie blue.
Old Mar 6, 2020 | 02:06 AM
the big cars had the same emblem, but are flat. I used them as marker lamps on my trailer.
Old Mar 6, 2020 | 02:15 AM
My 81 GMC was originally 350 Olds diesel powered, now it’s 455 Olds powered.
Unfortunately, GM started cross breeding in the late 70s. And engine swaps have been around since the hot rod hobby started. My problem is people who try to “fix” their Olds powered car by swapping in brand “X” engine because there cheaper. I remind them of all the money they will save once they buy a transmission, radiator, exhaust, wiring, accessory brackets, and all the other nickel and dime things that won’t interchange. Cheaper indeed!
Old Mar 6, 2020 | 09:30 AM
70cutty's Avatar
Beer Connoisseur
It can be done very cheap, people came up with ideas to use existing parts with LS swaps. You don't need a transmission, although having a 4l80E is nice. To do it right it might not be cheaper but LS is far more reliable platform to build. If I had known what I know now, I would've done a LS swap years ago, add a single turbo and be in 700RWHP without worrying when will my block fall apart.
Old Mar 6, 2020 | 10:34 AM
70W-32's Avatar
What about adding a mid to late 6o,s OAI system, and a pair of 69 W32 stickers to the front edge of the fenders, like the 69 442.
Old Mar 7, 2020 | 03:06 PM
4speed455's Avatar
The Parts Place has these Pontiac 455 emblems for $69 a pair shipped. They use adhesive so no drilling required.
https://www.ebay.com/itm/1959-75-All...r/352204183154
Old Mar 7, 2020 | 05:50 PM
Thanks for the info,I'll remember that. Those marker lights are the all time best!
Old Mar 15, 2020 | 08:14 PM
I found some Rocket emblems that I am going to use. They need cleaned up but I think they'll look good and make some ask questions.
fasstmonte
Aug 25, 2021 06:46 PM
64 Apprehender
Mar 5, 2020 04:35 PM
Jetstar455
Feb 26, 2016 02:55 PM
oldsmobiledave
Mar 26, 2015 08:34 PM
dhamster
Mar 2, 2014 12:42 PM
