i need your guys opinions
Okay so this is the first car i am tryin.g to restore. I put in a new engine tranny all that. Still need to add duals. Want to get a rearend and still need paint and interior. So i have been saving for paint. My friend told me that he thinks I'm doing it all rong. I should take care of the duals, do my rearend any suspension work I want to do. Then body/paint. then interior. I was planing on doing body/paint interior duals and rearend. Now I'm thinking if I should re think this
some one else will probably chime in. but if ur just doing exhaust and rear end u can probably have them do the paint first. bcause the duals and the rear end shouldn't accidently scratch the paint so u are probably fine going and getting ur paint done.
Dont know how far you have taken it down but I would get rear end done , make sure I have good brakes, line's, bushings ,tie rods , steering gear ,gas tank, sending unit, wiring , all that stuff to get it running good, tight and true.
then drive it for a summer and shake it down and not worry about crawling over the fenders that were just painted if you have to tune on it JMO.
Get all the 'under the hood' stuff done first, then the brakes, as brake fluid will eat paint!
Rear end entails brakes - even filling the master is a chance - so do it before paint!
Never seen a exhaust shop damage paint - so that could wait.
By the way - what're we talking about here - older cutlass or what?
That'd help to determine any pricing or parts availability!
Lets be realistic here......
How much money do you think you're going to invest into a 1977 Cutlass ??
There's going to be a line you draw before you waste too much you'll NEVER get back.
Draw that line first, then figure it out.
I'm not familiar with that [73-77] body style, so I don't know what'll fit.
You might put an add in 'parts wanted' and see what comes up.
You could install drum to drum yourself, but you need special tools and guages to rebuild yours, or pay someone else to do it.
If you put your location in your avitar, someone close might have all you need!
Good luck with your first car!
[QUOTE=Aceshigh;349920]Lets be realistic here......
Honestly the 77 are of of my favorite oldsmobile bodys, i love them. But that thought has ran across my mind. I no the 77 is a dog and even with alot of upgrades the weight holds it back. But they are so bueatiful. That why it came across my mind as i should just finish my duals, paint and body and be done with it. And have a nice cruiser cause my real car I want to build really bad is a 84 cutlass with a ls1 or lq4. That why I was thinking of keeping my gears and use it for a good crusier just finish my paint and interior by March how i planned. decisions are way to hard
QuinnKnight
November 7th, 2019 05:19 PM
rayfrausto
June 23rd, 2011 07:01 PM
