I have noticed several cars during this auction season that are painted underneath
the same color as the exterior body color. As an example, saw a really nice 70-442 with the under body in the same gorgeous matching paint as the exterior body. Did 70-442's come this way as new from the factory or was the under body a semi gloss or flat black (I think not, just curious).
Both AMC and Mopar routinely painted the under sides of their cars the same color as the body. There may be others as well but Olds was certainly not one of them - at least in the late 60's and early 70's.. They were all black underneath
It may be an over restored thing for most cars but not AMC and Mopar. I have a 73 Javelin in Trans Am red that is just as red underneath as it is on top. Not as shiney but just as red. I have also had multiple other AMC cars from that era and all were body color as well.
According to an "old" friend who worked at Fisher Body in Lansing from 49 thru 84 .
After the bodies were welded together , they were dipped in a huge vat of red primer.
They were then sanded "where it shows" and then went to the paint booths .
He told me about one time , there was a lengthy strike . And sheetmetal parts just sat for several months and got rusty . He said that when the strike was finally off and production resumed . The rusty parts were put in the jigs and were welded into bodies .
He also told me that when he started there , that everything had to be " just so " . Because " they hated to have warranty claims " .
By 1984 , when he retired , " anything goes ".
Not an expert on Mopars but if you watch the "Graveyard Carz shows, they painted everything body color. I know that just because they do it doesn't make it "correct" I suppose but given the level of restorations they do I would sure believe it to be correct.
my 70 Cutlass Supreme was gray primer with a moderate coat of Sherwood Green on most of the undercarriage and the int floors before stripping it. It was built in Linden NJ and also had 2 build sheets which I"m happy about
It would seem the Lansing cars were black underneath, but the other plants varied in the painting process. My 71 Supreme was built in Arlington, and it is red oxide primer for lack of a better description. It isn't flat as you would expect but more of a semi gloss.
You can see the green on the int and ext floors. I undercoated the floors in the 80's so that some of what you see. I'm sure my mother is gonna love being on the net after going 84yrs under the radar, LOL
ss0my69
February 20th, 2014 03:43 PM
mstudley265
July 28th, 2013 06:46 AM
ccnclassicoldsmobile
January 11th, 2013 01:01 PM
