How many where built ?
#42
Well Diego, in this case it would certainly be rarer because it would be one of none! ![Wink](https://classicoldsmobile.com/forums/images/smilies/wink.gif)
If it is an original floor shift SC, it has to be an M20 wide ratio 4-speed. That was the only floor shift option in '72 (even with the W30), and it mandated the 4-bbl 350 or a 455. Standard was still the ol' three-on-the-tree.
#44
And I verified this info front to back. Meaning it was not available, and didn't show up in the production records.
1971 was the last year for the M14 Heavy Duty 3-speed floor shift manual (the only floor shift 3-speed ever available). And in '70 and and '71, it was a GM trans, not the Ford Toploader used from '65 - '69.
#45
Kurt, what are these production records you speak of?
FWIW, I looked at the specs I have and it indeed shows M20 as not being available with the 350-2. I also don't see a floor-shifted 3-speed option. However, factory literature is not cast in stone, so I'll wait and see what happens here. :-)
#46
Anyway, there is no 3-speed manual there.
There is no doubt in my mind about this.
#49
Maybe someone went through this before, but that "we" wouldn't have included me!
https://classicoldsmobile.com/forums...ual-floor.html
again, i have no proof but i seen with my own eyes an original 72 3 sp floor shift car. with a Hurst shift lever, i do not know if the shifter was a Hurst but the lever was. i am not trying to be a problem but i know it is possible.
#50
Please accept my apologies and let me correct myself.
Yes, '71 *was* the last year for the M14 Heavy Duty 3-speed manual trans with the Hurst floor shifter.
However in '72 they continued to offer the floor shifter, but only with the same regular 3-speed manual trans as the column shifts got. So it was not given a "Mxx" RPO code as it was only a shifter change, not a transmission change. I thus missed the W39 RPO code given to it. Missed it in the "front" and the "back". I didn't have the production figures then that I do now, and I can now add that there were approx 475 3-speed floor shifters that made it into Cutlass S series cars, and that would include ones also 442 optioned.
And Diego, following your line of thinking, that is about 25% of the number of 4-speeds in the same series.
I promise not to forget *that* again!!
![EEK!](https://classicoldsmobile.com/forums/images/smilies/eek.gif)
auto_editor
Vista Cruiser & Wagons
April 10th, 2011 09:21 AM
HolidayCoupe
December 17th, 2009 11:53 AM
