How many Oldsmobile's do you own
Just the 1 Olds. I have worked on a 23 ford and a 29 ford and just sold a 52 Chev , the only car I have now to work on is my 69 Olds 98 convertible and she is by far the biggest car so it may take a while.
3 - just like Uncle Hulk. Four if you count the wrecked '68 W-34 Toro.
Three 1968 Toronados (red and gold ones are W cars, the sivler one I've had since late 1986/Jan 1987).
Dad sold his 63 Starfire he had from Jan 1989-July 2008.
Someday my plan is for another turnkey 63 Starfire
Hi,..........my name is John,.........and I'm an Olds-aholic.
I have the following project cars, all need work
1964 Cutlass 4 spd
1965 442 4 spd
1967 442 Automatic
1968 442 Automatic
1969 442 W30 Automatic
1970 442 4 spd
1971 Cutlass Flat Top Wagon
I have a 1967 Cutlass 4 door I use as a daily driver.
I have collected the following parts cars:
1964 F85 2 door post
1965 F85 2 door post
1965 F85 4 door (X2)
1966 Toronado
1967 Cutlass 2 door hardtop (project or parts?)
1967 Cutlass Convertible (project or parts?)
1968 442
1970 Cutlass Supreme
1971 Cutlass 4 door
1972 Cutlass 2 door hardtop
Over the last 10 years I've dismantled another 20-25 cars 1966-77
I have one bay of my garage full of engines, about 30
Way more parts than I have the time to organize. But hey, I'm having fun!
Someday I will have to downsize as I really don't have the time and money to complete all these projects.
But, for now,
1964 Cutlass 4 spd
1965 442 4 spd
1967 442 Automatic
1968 442 Automatic
1970 442 4 spd
1966 Toronado
1968 442
1971 Cutlass 4 door
But, for now,
OK he is SW's list of Oldsmombile/Olds powerd rigs:
Olds Cured Dash Replica (maybe made about trhe late 60s)
1904 Pie Wagon (6-wheeled street rod, with a c head 455!) built it under 10 months!
1923 Ford T- Bucket with a G head 455
1925 Maxwell Roadster with c head 455, two years to build
1928 Sport Coupe rare, got that 2 years ago
1935 3-window Olds coupe (as 455)
1950s:
1950 88 ragtop
52 98
54 I think
56
(3) 57s, two are Starfires(broaze and cream, the other is black and pink)-
all are J-2s
1958 ragptop j-2
1959 conv
1960 COnv
Satfires:
Three 1961s (the black one was maroon when new. Found out 6-8 years ago, THIS VERY SAME CAR HE BOUGHT NEW IN 1961!)
2 or 3 62s
green 63 ragtop
white 64 ragtop
1966 prject or parts car
1967s:
green 442
red Toronado (what dumb luck: red with balck top, rare options: disc brakes, am/fm radio, buckets seats with no console!, paid only $1500 and the former owner drove it from NY to Maine).
Plus a bunch of parts cars.
toro68, I figured I wasn't the only one with a driveway full! Although if you read the fine print you'll see that none of my projects are done. I've just been collecting project cars to tinker with and saving parts cars from the crusher, at least long enough to get some of the good stuff off. They don't salt the roads in Oregon and my home town is 300 miles from the nearest melting pot. So there's still a lot of old iron hiding behind barns and in the weeds. John
I have told him his Olds garage should be a meuem
I Got one,
A 1969 olds 88 delta converteble.
It's now getting a repaint, and than rebuild it.
there were to many dents and had him to a bodyworker.
I do want a olds older than 1960 if i finisch te 88.
Cars older than 1960 we don't pay taxes or have a yearly (checkup?)
So i only need oldtimer ensurance ( cheap) and drive
I only own one Oldsmobile 1948 Deluxe Club Coupe
I have owned my 1948 Oldsmobile model 66 Deluxe Club Coupe, for "55 years". I would say that it is 99% done. I would rate it a 2.5 out of 6.0, (1.0 being the best). It is a 3 speed standard transmission, with 56,000 miles on it. About 5 years ago I found 6 volt LED turn signal unit, for the rear window bar with 12 LED bulbs, (6 LEDs for the left and 6 LEDs for the right) for $39.95. I also had my original tube radio, converted to AM-FM-CD-Cassette, still 6 volt, with one 8" X 10" speaker. I added a "fader" and a "Boston" 8" X 10" speaker in the rear window deck. I now have Duel 8" X 10" speaker sound. There is a switch, on the bottom of the radio, under the dash, to switch from radio to CD/cassette. The volume is controlled through the radio. The "Beach Boys" sound fantastic. Every thing else is stock, EXCEPT, I put on 195-75 15" radials. The Oldsmobile has EVERY accessory, for that year, make, and model, EXCEPT, I did not drill a 1" hole into the drivers side pillar, for a spot-light mirror. My quote to the interviewers is "I do not go anywhere fast, I just look good getting there". Awards: My Oldsmobile has won: Best Oldsmobile in the Oldsmobile class, Best Car at the show, and Best GM car at the show. I have done 7 Weddings and 2 Proms. The Oldsmobile carries 1948 New York State plates. There were only 2,880 produced, in Lansing Michigan, in 1948, mine is #4.
1963 Dynamic 88 45k original miles, purrs like a kitten, floats like a boat.
1966 F85 holiday coupe, hi-comp, 4 bbl 330 4 speed (racecar), 1967 442 4speed, aluminum rod 468, hydraulic roller, badass.
1 - 1968 Oldsmobile 442 that I need to sell.....
because I got another Olds coming
I have had the ones in my signature at one time or another though.
Olds Owned
I have owned eighty Oldsmobiles in the past 30 years.
Current fleet
1965 442
1970 Cutlass W-31
1972 442 W-30
1972 442 Race Car
1973 442
1987 442 street strip hot rod
and a 1980 GMC 455 Olds powered.
Current fleet
1965 442
1970 Cutlass W-31
1972 442 W-30
1972 442 Race Car
1973 442
I only have one at a time, currently the '68 442. I usually only count the three 60's era cars. I've also had a '77 Cutlass S with a V6 that I inherited from my mother. Nice two door car with white exterior, red interior and Landau top, opera windows - but totally under powered
. I also had a '71 98 with the 455 and power EVERYTHING. Because it did not run when I bought it, I got it for literally $10. All I had to do to fix it was reinstall the distributor and plug wires. It turned over and started right up! There was more than $10 worth of gas in it when we towed it home, LOL! I was going to drop the 455 into my burgeoning Faux-Four-Two (black '68 Cutlass S). Getting rear-ended on the highway blew out that dream. But the insurance money is what funded my '69 442.
1967 Oldsmobile 98 × 3
1971 Oldsmobile × 3, 1 Royale convertible, 1 Delta Sedan, one 98, 4 dr.
1966 Oldsmobile, 2 Delta 88 Sedans, one Delmont convertible
1978 Cutlass race car.
1972 Cutlass Supreme
Parts cars, 1966 Cutlass, 1977 Cutlass, 1975 Delta convertible, 1985 Delta, that's about it.
Wow, 7 year old thread out of the archives!
1970 F-85 W-31 4 spd. W-27 Burnished Gold White stripe
1970 Cutlass post W-31 4 spd Black Red stripe
1972 442 (orange442)
1971 Cutlass S 41k survivor recent purchase
1970 Flattop Wagon (W-31 Wagon)
1970 F-85
1969 F-eightyfive 6 cylinder! Recent purchase
1970 442 4 spd post project
1970 F-85 rolling shell
1970 2 dr. parts car
1970 4 dr. running parts car
1970 4 dr. Hardtop running parts car
1972 Vista parts
1969 Toro parts
1968 Toro parts
1963 F-85 parts
Looks like 16 as well as a bunch of parts!
1970 F-85
1972 Vista parts
1969 Toro parts
1968 Toro parts
1963 F-85 parts
I have 7 , plus 7 parts cars. One 72 442, One 65 442, One 65 Cutlasses, 0ne 70 supreme, two 69 cutlasses, one 72 Cutlass.
Parts cars, one 70 olds 98, one 69 Cutlass, one 70 supreme, one 72 Cutlass S. One 65 442. One 65 F85 two door, One 65 cutlass two door hard top.
I think I need to sell a few.
Well only one, the Mistress, but I have bought all my driving age grand kids Oldsmobile's unfortunately no cars have survived through their teen age years. They took after their grand dad... Tedd
