hood insulation
Old May 16, 2018 | 08:28 PM
Tiberian Fiend's Avatar
hood insulation
What does it do? Do I need it?
Old May 16, 2018 | 08:43 PM
cjsdad's Avatar
Keeps engine heat from ruining the paint on the hood. Depends on how much under hood heat your engine generates and how attached you are to the money it costs to repaint your hood/car.
Old May 17, 2018 | 06:54 AM
Actually, the insulation is more for sound deadening than it is for heat insulation. I've run many Oldsmobiles with the pad missing with no ill effects to the paint. The "reduced sound deadener" claim for the W-cars is simply the deleted hood insulation pad, since it couldn't be used with the O.A.I. hood anyway.
Old May 17, 2018 | 06:54 PM
Thanks, Joe. I had to stick a low-profile air cleaner on my car and it was being smothered by the insulation.
Old May 17, 2018 | 07:27 PM
I removed mine long ago and never replaced it. The Texas sun will probably kill my paint long before the engine heat does.
Old May 17, 2018 | 07:49 PM
Rocketbrian's Avatar
Definitely for sound and not heat, as F85s being the base model did not receive hood pads.
flatfoot
Aug 24, 2020 04:52 PM
costpenn
Jan 2, 2018 06:46 AM
d4rksabre
Jan 29, 2014 10:30 AM
HouTXCutlass
Jan 10, 2011 12:58 PM
richeyb
Oct 11, 2010 06:44 PM
