Hood Flutter 1972 vista cruiser
I just took a 3000 mile road trip in my 1972 Vista Cruiser. The only problem was I couldn't tolerate was hood flutter. At 70-80 mph, my hood would start to flutter on both sides. I adjusted the side rubber mounts to tighten up the hood and it pushed the sides up too far as it stabilized it. It appeared as the middle latch needed to be adjusted down a bit. How is that done? The only solution I could see would be to lower the middle latch by adding washers to space it down. Any suggestions?
Sounds to me like it could be a simple few adjustments. If the hood sits high at the cowel adjust the springs. Lower the rear side. Look at it. Is it high in rear of the hood then goes down?
Flutter might be as simple as adjusting the front pins. Close the hood. Does the front of the hood feel loose? Like springy when it's closed?
Bluevista
Vista Cruiser & Wagons
November 9th, 2022 09:14 AM
