Hood Adjustment
Hood Adjustment
Anyone know how to adjust the rear of a hood. The rear of the hood on my 65 sticks up about a 1/4" above the fenders. It will push down and stay. I have no idea if the hinges should be adjusted up or down to get it to come back flush. The hinges appear to be in very good shape so I think it's just out of whack.
Check to see if your hinge mounting bolts are loose. When they are loosened, it allows the hood to be adjusted up or down. If it's not that, then possibly you've got some slack in the hinge, somewhere.
I got my hood to close perfect last night. I lubed it with PB Blaster, I had lubed it before but not with this. When I opened the hood I about knocked my teeth out it opened so easy and when you close it it lines right up with the fenders.
georgiaboy697
Jul 2, 2010 09:23 PM
