Here's a rarity
Old January 21st, 2017 | 11:24 AM
Here's a rarity
A 1968 442 for sale on ebay with the W-36 stripes and emblems located correctly!
Of course, the valve covers are on wrong...
http://www.ebay.com/itm/1968-Oldsmob...oAAOSw2xRYgoxi
Old January 21st, 2017 | 12:04 PM
ELY442's Avatar
Almost every car shows that I go to, the valve covers are placed on the wrong side
Old January 21st, 2017 | 12:07 PM
I just saw a comment from someone today that the notches were to clear the A/C compressor and PS pump.
Tell me how this helps clear the PS pump...
Even worse, this is the grommet for the PCV valve that goes on the other side in 1968 and DEFINITELY isn't plumbed to the air cleaner. DOH!
Old January 21st, 2017 | 12:08 PM
My2nd 69 442's Avatar
Joe, for those of us(me in particular) less educate (or as some may say "dumb a$$es") what is wrong with the valve covers?
Old January 21st, 2017 | 12:09 PM
The notches on the 67-72 A-body cars with BBO are intended to clear the brake booster and HVAC box, and thus go towards the BACK of the motor. It's pretty obvious in the photo I posted above that having that notch forward is doing NOTHING as far as helping any clearances.
Old January 21st, 2017 | 12:14 PM
Thanks Joe
I didn't see 2 above post until I had posted my question
Old January 21st, 2017 | 12:54 PM
66-3X2 442's Avatar
If I'm not mistaken,the 67 cars only used a notched cover on the booster side as there is no conflict with the evaporator housing. The evaporator housing on a 67 is in the cowl and the blower box isn't in the way. I also think that all 68's had notched covers on both sides if it was an A/C or P/B car or not. I could be wrong on that one but that's my understanding.
Old January 21st, 2017 | 01:01 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
That valve covers is an easy fix, silly to get wrong and the PCV is practically useless, almost as cool as my dual pcv valve Olds 260 was.
Old January 21st, 2017 | 02:56 PM
You are correct on both counts. 67 was the only year that used the early style HVAC box that didn't pose a clearance problem, but upgraded from the 9" booster to the 11" booster, thus one notched cover on the driver's side only. And yes, all 1968-72 A-bodies with BBOs got notched covers, regardless of the options selected.
Now, explain this motor that I saw at Carlisle a few years ago. It looked like completely untouched original paint on the covers. All I can figure is that since it has 7A heads, it must have been an end-of-production 1972 motor.
Old January 21st, 2017 | 03:03 PM
66-3X2 442's Avatar
Yep,that's weird one there. Never seen notched covers on a small block. It could be that it was a late production and they were using any and everything they had to deplete the inventory.
Old January 21st, 2017 | 05:39 PM
Carshinebob's Avatar
I have seen two 350 72's with notched valve covers. One of them belonged to the original owner and it also had a dual gate shifter even thought it wasn't ordered with one. I also assumed there was some sort of shortage near the end of production. ~BOB
Old January 22nd, 2017 | 07:44 AM
Considering that the 1973 motors changed to the valve covers with the OLDSMOBILE script, and the notched covers were no longer used, I'm guessing this is exactly what happened.
RocksRides
May 16th, 2013 02:15 PM
ThePackRat
October 30th, 2012 12:39 AM
Goat Cop
September 9th, 2011 04:39 PM
citcapp
November 20th, 2009 11:55 AM
stafoks
February 3rd, 2009 06:03 PM
