Help no spark at the ignition coil
Old April 23rd, 2023 | 09:19 PM
  #41
Originally Posted by Lazytoseizetheday
With ohm meter at 2k - to+ 12.87
+ to lead runnig to distributor 19.5
Coil is DOA
Old April 23rd, 2023 | 10:05 PM
  #42
No light when turning over 🤦🏻‍♂️
If you have no light on the high voltage lead with a timing light yet the test light flashes on the negative side of the coil (with the key on), then replace the coil. Be aware the car may start doing this. Just a note, those points look to be pretty burnt in the picture.
Old April 24th, 2023 | 05:01 AM
  #43
Post #14 you stated:
In order to check coil ( its new ) I was looking at old coil there’s a terminal still attached, looks like I pulled wire from idk
I'm not clear what the last part of your sentence references: "old coil theres a terminal still attached, looks like I pulled wire from idk", more importantly you stated "...coil (its new)..."
There are several reasons an IGN coil can go bad:
Key left in the ON/START position for an extended period of time (weeks, months, years)...sometimes typical of a car which has been sitting for an extended period of time;
IGN coil wire has developed cracks, abrasions, moisture intrusion, etc. - resistance increases and no spark or low quality spark develops;
Rotor button (on top) has corroded/cracked;
Rotor leading edge contact points corroded/cracked;
Distributor cap button (on top) has corroded/cracked;
Distributor cap contact points corroded/cracked;
Spark plug wires w/ cracks, abrasions, moisture intrusion, etc.;
Spark plugs cracked/corroded, incorrect gap.
Each of the above scenarios can individually or in combination cause an overwhelming increase in resistance to the ignition system. Since it's unclear exactly what is the current state of each, a solid recommendation would be to replace each of the following on a 56 year old vehicle:
Distributor cap
Condenser
Rotor
Ignition Coil Wire
Spark Plug Wires
Contact Points
Spark Plugs
Clean each of the wire terminal ends and points of contact where wires attach inside the distributor with a wire brush &/or sandpaper.
Voltage = Amps x Resistance
As Resistance increases there will exist a far greater demand to increase amperage to provide the same amount of voltage. This demand for an increase in amperage can bring a new ignition coil to its knees in short order if the resistance issues are not addressed.
Old April 24th, 2023 | 05:04 AM
  #44
As Eric pointed out, the points appear worn out - best recommendation is to replace each of the components identified above.
Old April 24th, 2023 | 10:01 AM
  #45
Lazytoseizetheday's Avatar
Definitely replacing coil points wires cap rotor and plugs
How to replace set points please
Old April 24th, 2023 | 02:25 PM
  #46
R&R of contact points is contained in the CSM identified in your thread Help me identify my 64 Oldsmobile 98 specifically Post8
I neither own a 1964 98 nor do I own the 1964 CSM. Search is your friend, also. You'll have to review which threads/posts are pertinent.
https://classicoldsmobile.com/forums...archid=6750317
Old April 24th, 2023 | 02:33 PM
  #47
This will give you an idea in principle.
Old April 24th, 2023 | 03:49 PM
  #48
You stated "....
...good for you.
The condenser should be replaced, as well. I am not sure if the ignition condenser resides outside (external to) the distributor or inside the distributor on your vehicle. Note in the video Eric posted they are attempting to nudge the distributor shaft so as to align the contact points "rubbing block" at the top (highest point) of one of eight "lobes" on the distributor shaft (one lobe per cylinder = 8 lobes/8 cylinders). You adjust the contact points gap when the rubbing block is on the highest point of a lobe - it doesn't matter which lobe. The contact points open at the top of each lobe and close in between the lobes. The voltage supplied from the ignition coil to the distributor (via the ignition coil wire) is supplied in "bursts" of electrical voltage as the contact points open & close. This opening and closing of the contact points induces the ignition coil electromagnetic field to collapse. The collapsing magnetic field induces voltage in the ignition coil winding. This voltage is in the direction to keep the current flowing. The faster it collapses, the higher this voltage becomes.
The purpose of the condenser is to (1) contain/capture/absorb increased spikes of voltage so that (2) there exists an immediate stop of voltage in between each opening/closing of the contact points. I note what might be arcing of your contact points. Yes, new contact points will most likely stop arcing, but more importantly you do not want to compromise the benefits of the condenser to the ignition system - it plays a vital role and it should be replaced.
Old April 25th, 2023 | 07:39 PM
  #49
Thank you
Yes referring to csm and video
thank you !
also replacing condenser 👍🏼
Last edited by Lazytoseizetheday; April 25th, 2023 at 07:41 PM. Reason: Adding to post
Old April 26th, 2023 | 05:10 AM
  #50
Replacing points condenser and ignition coil
As I desperately looked through csm for instructions I came to 30% with points in open position. Reading a related thread I realized .016 could have been ( gap ) . Not clear came at end of night. Also I am chasing grounds at distributor, starter etc.
Old April 26th, 2023 | 05:11 AM
  #51
A .016 point gap results as a 30 degree dwell on a meter. What grounds are you chasing at the starter and distributor as both mechanically ground to the engine?
Old April 26th, 2023 | 02:40 PM
  #52
Checking grounds
Power train starter ,engine , and battery should get me started
Old May 7th, 2023 | 09:10 PM
  #53
Cleaned ground and started right up
Clean ground to engine and ground to frame of engine bay and started up ty and now I get to fix brakes. I’ll have it fine tuned by a mechanic.👍🏼
tmd442
March 10th, 2021 12:44 PM
jonesolds442
July 24th, 2013 02:43 PM
navvet
February 18th, 2011 08:27 PM
ZOlds
March 3rd, 2010 05:37 AM
cisco88
January 27th, 2009 09:28 AM
Quick Reply: Help no spark at the ignition coil
