Help needed: 1971-76 Trunk Lock Emblem
A guy made this post in the parts wanted section:
"The only issue the original had was that the lense part had clouded up a bit thru the years. I was able to pop out the lense part, and found a nice super flat surface to slide it back and forth on some 600 grit sand paper, then went with ultra fine 1200, then some plastic lense polish."
I have the same issue with mine and would like to clean it up. My problem? How in the heck do you get the lens out without damaging the chrome or the lens? If you try prying it out it will certainly leave damage. Any thoughts on the lens removal would be appreciated!
Brenda K.
Brenda K.
goldie442
August 21st, 2015 11:01 AM
stlbluesbrother
August 20th, 2012 09:08 PM
