Help identifying a Part 1971 Cutlass
Old Jan 30, 2010 | 05:13 PM
dallasite21's Avatar
Hello, I have removed the fenders on my 1971 Cutlass and there is a rectangular rubber bushing/connector with 2 screw holes that the fender screws into. I have attached a pic. Does anyone know what this piece is andwhere I can get it? The screw holes on mine are worn.
Old Jan 30, 2010 | 05:24 PM
jensenracing77's Avatar
you want part number FB702L and FB702R from Fusick
http://fusick.com/catfile/Catalog%2043C_Layout%203.pdf
Old Jan 30, 2010 | 05:52 PM
Thanks alot... Do you know if there is a way to just replace the rubber part? It seems like such a waste to replace that whole brace because of that little piece of rubber.
Old Jan 30, 2010 | 06:06 PM
OldsMotion's Avatar
OldsMotion
I have a used pair if you don't care to pay Fusicks price for new ones. I can only imagine.
I found some generic exhaust hangars in my local parts store that I had considered trying to use the flexible peice out of. Its not just rubber... its reinforced with cloth.
John
Old Jan 31, 2010 | 09:06 AM
The rest of the brace is simply a piece of steel tubing. You'll need to take it off anyway to drill out the rivets even if you did find or make a replacement rubber piece.
Old Jan 31, 2010 | 09:27 AM
OldsMotion's Avatar
OldsMotion
Thats fine though, since it wont be original anyway, nuts and bolts can be used instead.
Old Jan 31, 2010 | 11:39 AM
Have you tried Steele Rubber Products?
They have a sheet of masticated rubber that matches this almost exactly. You just have to cut it to fit. Problem is they only sell it in 4 foot strips at 6.80/ft. Check around your local parts suppliers and see if they can't help.
I know how tough it can be taking the corroded bolts off this rubber. What I do is put the bolt head in a vice, cut off the lower bolt/nut and drill it out. That leaves the original part ready for re-use.
Old Jan 31, 2010 | 05:30 PM
Bluevista's Avatar
Registered
The rubber things were made out of old tires, I have one with a whitewall on it.
Old Jan 31, 2010 | 06:04 PM
hamm36's Avatar
... drill out the rivets even if you did find or make a replacement rubber piece.
I was thing of making some myself a year ago. Mine were not that band. I would go by a Tire Shop and ask if they have a old tire you can have. Cut it will some tin snipes.
TexasGunner
Mar 1, 2014 11:25 PM
rayfrausto
Mar 31, 2011 12:58 PM
kpl70sx
Non-Olds Engines
Dec 3, 2010 08:57 PM
sszewczuk
May 6, 2010 04:01 PM
LIMEGREEN71
Nov 25, 2009 05:30 AM
