Help about 69/71 TH350 Transmission
Old May 22, 2015 | 12:34 PM
Christophe2m6's Avatar
Hi guys!
Have a 69 Cutlass Supreme, 350ci, 4bbl, auto trans.
Noticed some oil under my car so checked my transmission pan.
As I was under the car, also checked the identification code and found: 71LA079N
So I guess I have a 1971 trans for a 350ci, 4200 series?
What is the "N" letter for?
Need new pan gasket and cooling lines...
I think that they use the same for 69 and 71?
Also, is there any difference if I have a 71 trans instead of a 69?
Thanks a lot for you help!
Chris
Old May 22, 2015 | 01:08 PM
No, they are externally identical. Get the lines, gasket, and filter for a 69. The differences will be internal, mainly the details of the shift point calibration. Not a big deal. The only other difference is that a 1971 TH350 will have an electrical connector on the case for the Transmission Controlled Spark system used that year. Just ignore it.
Old May 23, 2015 | 01:33 PM
Thanks a lot for your answer and help Joe!!
If someone have a good place to buy the transmission kit (gasket, filter...)?
I'm not looking for a cheap price but for reliable parts!
Thanks!
Old May 23, 2015 | 02:23 PM
toymobile's Avatar
Originally Posted by christophe2m6
thanks a lot for your answer and help joe!!
if someone have a good place to buy the transmission kit (gasket, filter...)?
thanks!
napa.
Old May 23, 2015 | 03:28 PM
Originally Posted by toymobile
napa.
Not that easy in Europe. I usually just get mine from RockAuto.
ddd777
Jun 17, 2019 11:42 AM
Tom442
Jul 17, 2013 05:01 PM
yeahbuddy
Mar 26, 2012 09:24 AM
84oldsDelta88
Mar 30, 2011 09:16 PM
dsolomon
Jan 22, 2011 01:12 PM
