Help
Help
Ok old gurus. I just purchased a 350 that was said to have come from a 72 delta 88. The only casting marks I see are on the rear of the block where the distributor is located. They read 135 and cad. And on the head there is a number 5. Any help would be greatly appreciated. Thanks in advance. I'd post some pictures but am not very computer friendly.
looks good so far. I haven't toe intro it yet but it spins with the breaker bar and was said to have ran when pulled. I'll probably rebuild it anyway. I pulled the distributor cap and turned the motor slowly. Looks like the timing chain is pretty stretched. I'll probably just rebuild it anyway.
Depends on your application I suppose. If money permits, better to rebuild, then you know what you're dealing with. At a bare minimum, if you throw a timing chain in and try to run with it, at least you'll be doing the front cover and oil pan gaskets correctly. This is very important, I learned the hard way.
ToronadoGuyDenver
Brakes/Hydraulic Systems
Mar 18, 2007 02:52 AM
