Help with 4 core radiator
Old Mar 8, 2015 | 07:55 PM
cdoering's Avatar
I have a 4 core radiator (at least that what the inside shows). The radiator is 2 1/2 think itself and 3 1/2 where it sits in the brackets (top & bottom). Both outlets (top and bottom) are 1 1/2. The radiator cap is not level and at an angle. The length from where the top / lower brackets sits is 29 inches and the overall length is 33 inches with a height of 18 1/2.
Questions:
1) Is the correct size radiator for a 70 442 w30 with A/C? What issues will I have with the shroud (I have a 19 inch fan blade).
2) I know I would need to have the lower inlet changed. The radiator has been tested and all coils are straightened (radiator shop did work on it).
3) There are not letters on the side IF or IC.
I do have a 4 core radiator top plate.
Chris
Alex72cutty
Apr 21, 2015 10:30 AM
rcktdoc
Jul 14, 2014 12:38 PM
59Olds98
Aug 14, 2013 09:38 AM
L69
May 19, 2013 11:01 AM
kevdog442
Jan 3, 2009 03:21 PM
