Hedman header identification
Old Sep 28, 2021 | 07:51 PM
deadeyejedi's Avatar
does anyone know how to tell the difference between big block and small block Herman headers ? I have a set that are supposed to fit a 455 but I see no numbers on them only the Hedman tag on them. Thanks
Old Sep 28, 2021 | 09:03 PM
I would say at least grab a tape measure. Should be very easy to identify. Post pictures and those in the know here will answer immediately.
Old Sep 29, 2021 | 03:30 AM
will do and thanks .i tried to edit my title for the incorrect spelling of hedman but wasn't able to
Old Sep 29, 2021 | 01:19 PM
Old Sep 29, 2021 | 02:53 PM
Fixed your title. Can't help on the headers just looking at your picture.
Old Sep 29, 2021 | 02:59 PM
Thank you Eric
Old Sep 29, 2021 | 03:05 PM
Interesting how they spell “hedders” on the stamp. The guy I got these off said they were on a 70 442 with a 455 . I bought them just to use on my run stand but they’re actually in pretty good shape ,maybe use them on a future project .
Old Sep 29, 2021 | 03:52 PM
I bet there is a part number stamped somewhere. You might call Hedman and ask if they could help identify them.
Old Sep 29, 2021 | 07:50 PM
70W-32's Avatar
Check around the collector flange, some companies used to stamp part numbers there.
Did you use these on your run stand? SBO hedders on a big Olds wont clear the starter or oil filter mount correctly
Old Mar 19, 2022 | 04:15 PM
I did finally get back to these hedders after some wire brushing at the flange I found a part number 58150. They are big block olds hedders I’m using them on a 350 I’m working on the run stand . They did need to be clearanced around the motor mounts but for 50 bucks I don’t mind banging them in a little.
scj64
Jul 22, 2020 10:01 PM
Mark71
Aug 1, 2011 03:03 AM
scott71
May 23, 2011 07:20 PM
nonhog
May 15, 2008 03:18 PM
nohn
Oct 26, 2007 06:21 PM
