Hedman header identification
does anyone know how to tell the difference between big block and small block Herman headers ? I have a set that are supposed to fit a 455 but I see no numbers on them only the Hedman tag on them. Thanks
Interesting how they spell “hedders” on the stamp. The guy I got these off said they were on a 70 442 with a 455 . I bought them just to use on my run stand but they’re actually in pretty good shape ,maybe use them on a future project .
Check around the collector flange, some companies used to stamp part numbers there.
Did you use these on your run stand? SBO hedders on a big Olds wont clear the starter or oil filter mount correctly
I did finally get back to these hedders after some wire brushing at the flange I found a part number 58150. They are big block olds hedders I’m using them on a 350 I’m working on the run stand . They did need to be clearanced around the motor mounts but for 50 bucks I don’t mind banging them in a little.
