Heck of a burn out ==> disappointed
Old Jun 23, 2017 | 01:54 PM
jimbr70's Avatar
So now that my car's front end is happy, I just needed to laydown a burnout in celebration. Well, despite what I was told, it ain't an "anti-slip" diff.
It has 12 bolts holding the cover so I think that means a 10 bolt carrier inside. Will look for numbers stamped on the diff and see if I can figure out what it is and if it is reasonable dollars to convert - with 1 wheel drive, it makes no sense to do anything for horse power if I can't use it. There's more confusing mumbo-jumbo talk online about differentials that any other part of the car. Time to study.
(and I'm not touching the AC leak issue in this heat wave)
Old Jun 23, 2017 | 02:14 PM
A 1970 Cutlass should have an O-Type rear, which as you said has a 12 bolt cover and a 10 bolt ring gear. There are different series carriers for different gear ratios, with one for 2.56 and 2.78, one for 3.08 and 3.23, and another for 3.42, 3.91, 4.33, etc. You may actually have an anti-spin and the clutches are worn out; gotta remove the cover to verify if it's an open carrier or a posi.
Any idea what gear ratio you have? Some carriers are more plentiful than others.
Old Jun 23, 2017 | 05:50 PM
wr1970's Avatar
There is a code stamped on axle tube.Should be on passenger side.You may need a wire brush to find it or scotch bright.
PM70
Jan 31, 2017 11:17 PM
import extermination
Jul 15, 2013 10:06 PM
Bill in NC
Sep 12, 2011 08:26 AM
jo75olds
Feb 18, 2011 09:26 AM
73Ninety8
Ninety-Eight
Oct 21, 2007 03:27 PM
