Heater box rehab
Old Jul 20, 2014 | 05:48 AM
smash72's Avatar
Smash
Heater box rehab
72 Cutlass tore into the heater box over the weekend. Pretty sure it's the first light of day since 72.
Anyone know the sealer being used between halves also will need a new gasket for the AC coil but that shouldn't be a problem. The sealer has to be better now than this crumbling wax stuff.
Also is there a spray on splatter paint I can use on the outside fiberglass itself ?
Since it was in such bad shape steel wool & a Dremel buffer was the only way to bring it back now it's a little dull. Tried a detailer looks ok but I would rather paint it I'm **** like that.
Old Jul 20, 2014 | 07:34 AM
501Paratrooper's Avatar
I lightly sanded mine with 1000 grit and then put a coat of low luster clear. I used the black strip calk for the firewall seal.
Old Jul 20, 2014 | 07:39 AM
Lady72nRob71 posted a really good detailed description of what he did for his 72 heater core replacement.
https://classicoldsmobile.com/forums...placement.html
Old Jul 21, 2014 | 02:04 AM
Yellowstatue's Avatar
If it's original, the heater core will have the year stamped into the end tank where the hoses connect...
Old Jul 21, 2014 | 11:54 AM
banny's Avatar
in my opinion, painting the housing makes it kind of tacky looking. I bead blast and clearing coat all the units I restore.
Old Aug 2, 2014 | 11:22 PM
smash72's Avatar
Smash
That's why I ask you guys clear it is. Also don't see a year stamp only the Harrison stickers 1 on the outside of the box and a diff # sticker on the A coil.
91Bravada
Dec 5, 2014 09:24 AM
LI Olds
Dec 30, 2013 05:23 PM
old80cs
Dec 9, 2012 05:05 AM
jeffs 89 cutlass salon
Oct 10, 2007 05:34 PM
DJMatthews
Jan 26, 2007 05:59 AM
