heater box control cables
Old Apr 5, 2017 | 01:20 PM
ben442's Avatar
68 442, non air, I've got a broken cable on the cool-warm control slider that connects to the inner heater box, and the other cables are stiff.
Where can I get new ones if possible? Also are the defrost vent tubes available anywhere?
I've looked online but I may be calling these parts by the wrong names....any help....
Thanks, Ben
Old Apr 5, 2017 | 01:59 PM
frankr442's Avatar
If all that's broken is the inner wire, that's easily repaired if you can find a dealership with an older parts department. We used to have a kit with wire and a tool to make the end coils. kit also included casing and some end clamps if needed.
Probably got thrown away when we moved, I should have grabbed it!
Such a kit is likely available aftermarket.
Old Apr 5, 2017 | 02:09 PM
Yellowstatue's Avatar
If you wish to consider pre-tested cables, call me @ nine zero five 775 OLDS.
jdana24
May 25, 2016 12:53 PM
tcarroll
Oct 12, 2012 12:20 PM
D Appeldorn
Apr 1, 2011 10:37 AM
D Appeldorn
Jun 9, 2010 05:42 PM
