Headlights
Old Jul 22, 2024 | 04:07 AM
Mikeyt's Avatar
Mikeyt
Headlights
What do you guys use?
I've got a 62 98 and want the brightest stock looking bulbs.
I see the Syvania Silverstars but they only come in low beam. Then there is the extra vision which is a step down but they come in high beam.
Not sure what the deal is but if they look the same off I'm ok with 2 types but really wanted the brightest out there. Stock style of course not some Manny MO and Jack starter pack laser lights. 😁
Old Jul 22, 2024 | 05:54 AM
I use Wagner halogen bulbs.
Old Jul 22, 2024 | 06:35 AM
Sugar Bear's Avatar
The more expensive lights e.g., Silver Star vs. Extra vision are a little brighter but don't last as long. If the car isn't a daily driver it's a non-issue. Do make sure all connections are clean, bright and tight to prevent connectors from burning...been there.
Old Jul 22, 2024 | 07:03 AM
Mikeyt's Avatar
Mikeyt
Can't seem to find Wagners around here.
I'll look online.
Brighter the better I can't see a thing with the ones in it now which I have no idea how old they are.
Not a daily driver but will be a never driver if I can't see any better than how it is now.
Old Jul 22, 2024 | 07:05 AM
Old Jul 22, 2024 | 07:18 AM
As you can see, the part numbers for the lamps are H5001 hi beam and H5006 low beam. Any manufacturer with these part numbers will work.
Old Jul 22, 2024 | 08:06 AM
Mikeyt's Avatar
Mikeyt
Thanks again Joe
I will add this to my alternator order👍
Old Jul 22, 2024 | 08:07 AM
Mikeyt's Avatar
Mikeyt
Yeah I was just wondering if one was better than the other and if there were any brands to avoid.
I've been out of the old car scene for close to 15 years now and as I am finding out parts wise things are a but different now.
Old Jul 22, 2024 | 09:13 AM
GN1220's Avatar
Step up to LEDs. I forget the manufacturer but the old style round bulbs in LED are out there.
Old Jul 22, 2024 | 09:27 AM
VC455's Avatar
Barely Registered
If you have some wiring skill, the most significant thing you can do to give brighter headlights is to install two relays with circuit breakers (one low beam, one high beam).
Wire so that the relays deliver current directly from the horn relay post to the headlamps. Actuate the relays with the existing headlight wiring.
On our old cars, this rewiring comes close to doubling the headlight output.
I've done this for myself and friends. No one believes the light will double until they see it.
Old Jul 22, 2024 | 09:39 AM
Mikeyt's Avatar
Mikeyt
I thought about it but all the ones I see don't look stock.
Old Jul 22, 2024 | 09:40 AM
Mikeyt's Avatar
Mikeyt
interesting.
Old Jul 22, 2024 | 01:18 PM
Also make sure the headlights are aimed properly. The brightest light doesn't do much good if it's shining up in the air or on the ground 2 feet in front of the car.
Old Jul 22, 2024 | 02:00 PM
... on the ground 2 feet in front of the car.
At least that way it won't blind oncoming traffic.
Old Jul 23, 2024 | 02:31 PM
Bryan Burch's Avatar
I put these on my car, because as I age I feel like I'm getting a little night blind. These are like modern car headlights in an old school housing. I love them.
Holley RetroBright LFRB145 Holley RetroBright LED Forward Facing Light - Modern White (5700K)
Old Jul 23, 2024 | 03:17 PM
dc2x4drvr's Avatar
Yes, this is the best modification to improve our headlight output period..
Old Jul 23, 2024 | 03:35 PM
$386 for a set of headlights seem a bit on the expensive side to me. I dunno about everyone else, but I don't spend that kinda money on my Cutlass.
Old Jul 23, 2024 | 03:57 PM
Gary - Excellent suggestion...
Old Jul 23, 2024 | 05:09 PM
Mikeyt's Avatar
Mikeyt
Thanks cheif
Gary was kind enough to send me a bunch of info on this mod.
I've got new Wagners on the way and will be doing this mod soon as I can.
Old Jul 23, 2024 | 05:12 PM
interesting.
Thanks cheif
It isn't EXACTLY as Gary stated w/ 2 relays (several ways to skin a cat), but the video I posted demonstrates some basics I thought you might appreciate. Glad Garry helped you out.
Old Jul 23, 2024 | 05:21 PM
Mikeyt's Avatar
Mikeyt
I very much appreciate the video.
I am a visual learner and the more info the better.
Thanks again👍
Old Jul 30, 2024 | 06:59 AM
brian060901's Avatar
Hi again, thanks for all the help, it is wonderful.
Any chance someone can send me a copy of the "Video", or where to find it.
Any info would be greatly appreciated, I am confused how that would not interfere with the horn, but then again I'm not a mechanic.
Old Jul 30, 2024 | 07:48 AM
The video I posted (above) in Post #18 is located on YouTube. Just click on the video to watch. I cannot send you the video. There may be "other" videos, as well.
Old Jul 31, 2024 | 07:53 AM
Commonly, the device Gary referenced in Post #10 is often termed a horn relay. It is actually composed of two parts: (1) a horn relay itself contained w/in the aluminum metal canister; and, (2) a distribution/junction block which distributes power throughout the vehicle. Note the distribution/junction block is a metal (threaded) post where power wires attach (as Gary stated - the horn relay post). Depending on model/type it is listed as a horn relay by many parts supply houses because the horn relay is contained on the distribution/junction block platform. Many (most) are sold as a horn relay, again this dependent on model/type of what is called the horn relay. Some of these devices, it is possible to change out the horn relay separately from the distribution/junction block. The wiring will not interfere w/ the horn. As noted the relay wiring goes directly to the distribution/junction block (as do all other power wires for your vehicle) to distribute power.
Typical Horn Relay (Distribution/Junction Block)
This is a separate horn relay.
Old Aug 2, 2024 | 01:39 PM
dfakes's Avatar
I did a similar wiring project on my 1964 El Camino. The difference is amazing. No longer are headlight at idle about as bright as a small birthday calendar. I did the feed to the relays directly from the side post connections on the dual terminal battery (with a proper circuit breaker to protect the circuit). If you really look at what powers the headlights in stock form, it is small gauge wire running from the battery area to the headlight switch, to the dimmer switch to the headlights.. It is a wonder that they ever worked.
On Holiday
Aug 12, 2021 04:16 PM
Nop
Oct 9, 2014 07:49 AM
Raydermiike
Nov 16, 2013 08:31 AM
Aceshigh
Sep 29, 2010 04:36 AM
70special
Sep 29, 2010 02:38 AM
