Header-steering lock rod interference
Old Mar 31, 2019 | 10:33 AM
Platinum69's Avatar
The header interferes with the steering lock rod that goes down to transmission. Anyone ever experience this and what was your fix? Thank you
Old Mar 31, 2019 | 11:04 AM
What are your vehicle specifics: year, engine, manual trans or automatic, console or column shift?
Old Mar 31, 2019 | 11:27 AM
Platinum69's Avatar
69 442 with 350 motor th350 trans with console shift
Old Mar 31, 2019 | 12:29 PM
don71's Avatar
same but different
This can happen as all headers are not made equal.
At some point I removed the back drive linkage and installed a different manual selector shaft bracket to get around that problem. Be aware you will lose the function of back up lights and it circumvents the neutral start switch as the shifter bowl stays in the park postion...unless you manually move it with your hand. This is not a good solution and neither are ill fitting headers.
When i went to a big Olds I was able to put those parts back on as these different headers didn't impose a problem.
Old Mar 31, 2019 | 06:33 PM
Platinum69's Avatar
Maybe I'll have to come up with something temporary til I put the big block back in.
Old Mar 31, 2019 | 10:37 PM
dragline's Avatar
Do you have a picture of where it is interfering? I think there is some fixes on Youtube or Google search. I believe someone makes a kit or rod to route around the header. You might be able to bend the rod you have. Good luck.
Old Apr 1, 2019 | 07:19 AM
ronskal's Avatar
Read the attached pdf which gives instruction for modifying the shift arm for a Hooker Header install.
It may work or shed light on a solution since we do not know what type of headers you have.
File Type: pdf
Old Apr 1, 2019 | 09:22 AM
Platinum69's Avatar
I'm not sure what headers they are but that should be a big help to modify the rod arm. I'll post a picture later. Thank you
O-dawg
Nov 19, 2016 11:55 AM
Dmaxheimer@bellsouth.net
Sep 26, 2015 12:49 PM
NMcCarthy
Nov 16, 2014 08:03 AM
andyman
Feb 2, 2013 07:47 PM
WTony
Jun 24, 2010 09:15 AM
