Head and Intake milling question
Is there a formula for sbo that shows if you take X amount from the head you then need to take Y amount from the intake so all bolt holes etc line up properly? Do they mill the head side of the intake or just where the intake meets the block? What about the head where it meets the intake manifold?
FYI- building a 380 stroker sbo with Procomp heads and Edelbrock 7111
Perfect! Just what I could not find....of course I was at work
![Roll Eyes (Sarcastic)](https://classicoldsmobile.com/forums/images/smilies/rolleyes.gif)
Actually, the Olds is easy in this respect, because the manifold flange is at a 90° angle to the deck surface, so the number is always the same: If you remove 0.010" from one surface, you remove 0.010" from the other surface.
Joel
April 26th, 2017 01:37 PM
RAMBOW
July 31st, 2011 01:59 AM
