Harmonic Balancer ?
Old Aug 10, 2011 | 03:41 PM
jag1886's Avatar
Harmonic Balancer ?
Is there a way to tell with the balancer off the engine whether it has slipped or not? I would think that there would be an alignment mark somewhere on the inner hub but I can't see anything or I'm not looking for the right thing.
Old Aug 10, 2011 | 10:35 PM
svnt442's Avatar
If you can't find an alignment mark then you'll have to get the engine to TDC using a piston stop and a degree wheel and then install the balancer to confirm if it's spun or not.
Old Aug 11, 2011 | 04:07 AM
This may help you.
Old Aug 11, 2011 | 05:50 AM
Lee_A's Avatar
Originally Posted by jag1886
... I would think that there would be an alignment mark somewhere on the inner hub but I can't see anything or I'm not looking for the right thing.
Whenever I build a motor, I use a cold chisel and make my own alignment marks.
I also try to verify TDC on the timing pad, before I put the heads on.
Lee
Old Aug 11, 2011 | 08:51 AM
jag1886's Avatar
Lee
I'm just trying to determine if the balancer has slipped, if it has I need to get it rebuilt.
rroth01
Dec 3, 2016 06:27 AM
Gert3116
Apr 23, 2008 08:53 AM
bmbraun
Feb 25, 2005 12:17 PM
martine
Apr 2, 2004 09:25 PM
Clint Reno
Aug 10, 2003 10:03 PM
