Hardened Valve Seats?
My E heads from a 1970 442 are going to the machine shop to be resurfaced for new head gaskets. Should I have the valve seats hardened? or is that a myth that the unleaded gas will cause valve seat damage? There is 48K on the engine.
I do not know of any way to harden the valve seats other than replacing them with hardened seats. Unless your machine shop is familiar with doing this to Olds heads, do not do it. I ran a 67 400 for over 75K miles, both intown and highway miles and had no valve recession.
If the seats haven't recessed, they likely aren't going to, unless you are planning on installing it in a motorhome or tow a trailer with it.
I would not replace the seats. As mentioned, that's the only way you harden them. The old ones get milled out, the new ones get pressed in.
Hardened exhaust seats
But make sure whom you have put the seats in is familiar with Oldsmobile heads or if possible done it before. The water jacket is very close. If they cut into it you will have boat anchors instead of heads. I had my small combustion chamber heads ported polished and exhaust seats done. You maybe money ahead to just get some new aftermarket heads😀 do not I repeat do not just use the soft seats. Unless you are put put put around driver. And even if you are they will still fail at some point.
Yes you need hardened exhaust seats or run lead substitute which isn’t great. I ran my 455 without hard exhaust seats and beat the valves back into the head in 15,000 miles. If you are going to have any fun at all with your car at all. I am not talking racing
This is a perfect example of why a post SHOULD be revived.
the info given out here is total bs. Olds heads do not need hard seat in virtually all cases. Even when using Titanium valves in an all out race app with big spring pressures..they can be cut oversize and survive.
usually the only reason for a seat insert is if they can’t be recut for the stock size valves without sinking them or there is a minor crack in the seat area.
Both my jet boat and my motorhome have heads without seat inserts. If your afr and timing is what it should be, there should be no reason to burn an ex valve…which is what burns, not the seat in the head. a stainless ex valve would be the only upgrade, if any.
if you are worried about burning an ex valve..keep the seat 30deg and extra wide to help pull heat out of the valve head with factory rotators
Had it not been revived, no one would have paid any attention to it. Should we go back and correct every bit of incorrect info in every old thread, just in case? I do agree with you as far as the need for seats is concerned.
As I've said before, the issue isn't reviving a threat that's relevant. The problem is that invariably someone revives a long-dead thread with a question that usually isn't even related to the title of the thread, and people start responding to the original question and not the new one, which usually results in even more incorrect answers.
here in this case though the op never responded after his initial question..so nobody knows what he ended up doing, so reviving it should help someone decide. It’s a short one so you don’t need to read through pages of responses.
another thing is how do you use the search to find good info that isn’t mired in fifty pages worth of responses in posts that have gone off the rails?
blocking or locking out old posts that have dreadfully inaccurate info don’t seem right…especially where that info can still be seen and taken as legit when using the search function….like if someone specifically revives it to ask..hey, is this correct?
The info given out here is total bs. Olds heads do not need hard seat in virtually all cases. Even when using Titanium valves in an all out race app with big spring pressures..they can be cut oversize and survive.
Well I'm sure glad I came across this one. I was thinking of having hardened valve seats installed and now I'm thinking it doesn't really make any sense at all unless you had no other choice. Even then if the heads couldn't be saved unless you had to press a seat in, I think you would be better off replacing the head. A joint is a weakness and it doesn't take an engineer to figure that out. What about two metals of different compounds and the way they respond differently the expansion and contraction of heat? I haven't taken my heads off yet but will very soon. Its good to see discussions like this.
Yeah I think its just a simpler matter that depending on the conditions, valve seats may get damaged period. Lead is extremely soft. How do we know that the lead theory didn't originate as a marketing ploy. Lead helps with pinging. Heat and friction causes metal damage. I dont see a dusting of lead being enough to offset that.
I see, I would just love to see the exact scientific data on this because it would seem to me that the benefits the lead does yield to proper combustion (which has been scientifically proven and documented I'm sure you know) could in itself be then linked to overall internal temperatures and then excesses of friction. Which then in turn could be applied to the actual rate of wear. I've searched intensively for the data on the actual contact of the lead to the valve seat and what benefits this would yield but I haven't yet found an acclaimed study. Needless to say I've never seen these two studies then compared against eachother. Obviously driving habits and maintenance would be massive variables here. I'd be willing to bet though that there are many people whose valve seats have worn, all of these factors apply to some degree, and harder metal is one solution but a whole head that is of a harder compound has to be incomparably better than just only a hardened seat. To the point that the only logic here would be a last resort to save the head that is not otherwise salvageable, that the posesser of that head has an attachment to. If you want to keep your head and the seat can just be ground and that will get you another 90k out of that particular seat on modern fuel than thats what it is. Is this line of thinking correct?
https://en.wikipedia.org/wiki/Tetraethyllead
X 2
Can you translate this to simpler language ? Read this about Tetraethyl lead.....
X 2
X 2
Well I'm sure glad I came across this one. I was thinking of having hardened valve seats installed and now I'm thinking it doesn't really make any sense at all unless you had no other choice. Even then if the heads couldn't be saved unless you had to press a seat in, I think you would be better off replacing the head. A joint is a weakness and it doesn't take an engineer to figure that out. What about two metals of different compounds and the way they respond differently the expansion and contraction of heat? I haven't taken my heads off yet but will very soon. It’ good to see discussions like this.
Not only that but It caused me to look into any other machining of the heads like port and polish and all that. I see no benefit in modifying heads at all unless absolutely necessary but this does pertain to a daily driver not a racecar.
..... The problem is that invariably someone revives a long-dead thread with a question that usually isn't even related to the title of the thread, and people start responding to the original question and not the new one, which usually results in even more incorrect answers.
I would like to add that before I joined every time I Googled a specific Olds question this site came up which is ultimately why I joined. ALOT of the info I was looking for I found in your oldest theads. It actually doesn't matter if people are responding to the wrong threads or not. If you Google a question it pulls you to the answer. It doesn't care what the original question was, it's pulling you to the keywords you're typing in. I should say its not the only thing that matters, of course you want to keep things organized.
1966 Toro B Heads
By the way my heads are now off. The seats don't appear to have any visible damage. I ran the car for 3000 miles 93 octane 10%ethanol. Looks like one exhaust valve is burned . I keep trying to download a pic but it won't right now.
