Goose neck
Old Feb 21, 2012 | 01:55 AM
ralsy's Avatar
Goose neck
Any idea why some 69 442s came with a thermostat housing with a metal goose neck for the bypass and some came with the straight neck bypass where you needed the goose neck hose?
Hope i made some sense, don't want to look like a goose
Old Feb 21, 2012 | 03:16 AM
I believe that the changeover from the thermostat housing with the small straight nipple and J-shaped hose to the water pump was superseded by the thermostat housing with the J-shaped nipple and straight hose between the '70 and '71 model years, because of problems with the long J-shaped hoses (and need for a more expensive special hose instead of a cheaper short piece of regular hose).
I may be wrong, but... '69 and '70 should both have the straight nipple / J-shaped hose it they're original.
dnmfranco
Aug 3, 2013 05:05 PM
Aceshigh
Aug 22, 2011 12:47 PM
Jamesbo
Nov 24, 2009 11:05 AM
1FSTLS1
Mar 4, 2008 06:51 AM
shaks 442 clone
Jul 18, 2007 05:03 AM
