Are GM Interior Paint Codes The Same Between Makes?
Old Aug 14, 2022 | 01:42 PM
olds70supreme's Avatar
I'm restoring the dash in my '75 Starfire. The interior color code is 26V, which is a blue color. I've found a '75 Corvette color code 26V, along w/ a source for the "Corvette" 26V vinyl dye. Can I be confident that a GM 1975 26V paint code is the same color between makes (Chevy vs Olds)?
Thanks.
Old Aug 14, 2022 | 04:44 PM
442Harv's Avatar
Most paint shop will mix a small sample, to see if it matches. I know some of the outside colors, have same code, but called a different name.
Old Aug 14, 2022 | 06:58 PM
Yeah, my problem is that the interior was already refinished to a different color by the PO, and the car saw a lot of sun judging by the plastic pieces - I don't have any good "original" samples to use.. Originality isn't everything to me but I'd like to get it to look as close to "correct" as possible.
Gbryant
Nov 24, 2020 12:11 PM
jensenracing77
Nov 30, 2019 11:46 AM
tcolt
Dec 22, 2016 03:45 AM
Wedgewood Rod Shop
Mar 19, 2014 02:00 PM
1968 42
Apr 12, 2008 07:32 PM
