Getting closer.
Old Oct 24, 2009 | 09:48 PM
nukesec1's Avatar
Getting closer.
Installed the carb and fuel line from the pump to the carb, replaced some vac lines, hooked up the few wires that needed hooked up (oil pressure, carb something-or-other, temp sending unit) and put my fat elbow on the temp sending unit and bent the little metal "tang" thing down. Might need to replace that! All I need is the choke stove gasket which will be here Tuesday. I am crossing my fingers that this all goes well when it's time to hit the ignition switch. Wish me luck!
Old Oct 25, 2009 | 07:54 AM
Cecil Anderson's Avatar
You don't need luck when you are good, it will kick right over and sound great. Andy
Old Oct 26, 2009 | 06:37 PM
meoff's Avatar
Good Luck!!! Now lets get that thing fired up
Old Oct 27, 2009 | 05:24 AM
Oldsguy's Avatar
Past Administrator
If possible, don't bend that electrical "little tang thing" back. If you can connect the wire to it without bending it back do so as those things are brittle and it may break.
Old Oct 27, 2009 | 07:59 AM
citcapp's Avatar
I try to never bend my thingy's, a bent thingy is a bad thing. I am sure she will start right up, I can almost hear it from here
Old Oct 27, 2009 | 09:31 AM
cutlassgal's Avatar
Cutlass Lover
Bent thingy's!! You crack me up!!
oldsconv
Apr 20, 2015 06:56 PM
70Post
Mar 2, 2010 07:33 PM
Moofinator
Ninety-Eight
28
Jun 4, 2007 09:13 PM
muttmeg
Ninety-Eight
Apr 21, 2007 09:26 PM
WesB.
Apr 14, 2007 09:16 PM
