Ga heads value
Old Apr 23, 2014 | 06:11 PM
Kyle's 77 Cutlass's Avatar
Ga heads value
Hey guys, what's the value of Ga heads? Thanks
Old Apr 23, 2014 | 06:16 PM
New? Used? They are specifically 1972 455 heads. Good too - they have hardened valve seats on intakes and exhausts.
Old Apr 23, 2014 | 06:21 PM
Octania's Avatar
A lot depends on condition- a refreshment valve job can cost several hundred dollah
Old Apr 23, 2014 | 06:33 PM
Sorry, not too much info on them. Sent the guy a email on them. Sounds to be used, and not sure if they need a rebuild. Was reading the olds faq's on 72 Ga heads, could be WO heads. If they are, does that make them worth more than just standard Ga's?
Old Apr 23, 2014 | 06:39 PM
jensenracing77's Avatar
You only have big valve or small valve Ga heads. Don't much matter if they were on a W-30 other than they would have been big valve. For the most part, any heads you buy should be considered cores needing rebuilt. I sell BBO heads for $50 to $100 each.
Old Apr 23, 2014 | 06:42 PM
oldstata's Avatar
Justin
you only have big valve or small valve ga heads. Don't much matter if they were on a w-30 other than they would have been big valve. For the most part, any heads you buy should be considered cores needing rebuilt. I sell bbo heads for $50 to $100 each.
x2
Old Apr 23, 2014 | 07:40 PM
Okay, thanks for the info. Not worth chasing then
Old Apr 23, 2014 | 07:48 PM
2blu442's Avatar
Well... how much is he asking? Prices do vary from different parts of the country/world depending on what's available. If you don't have many big block heads showing up on the local classified ads you might think about it. I've been selling big valve heads for $150 a set in my part of the country.
John
Bens71442
Jul 3, 2014 02:35 PM
joejames
Jun 18, 2013 04:16 AM
Napoleon Solo
Apr 24, 2013 11:02 AM
jagerfritz
Feb 14, 2012 02:50 PM
gearheads78
Nov 10, 2009 09:31 PM
