Fuel Tank questions 68 Cutlass
I need to install a tank on my car, no old tank to look at. I am not sure what all I need. Tank, sending unit, straps and bolts, cap,,,,,
1. Do I need a vented sending unit?
2. If so how is it configured?
3. What about a return line? Required?
4. If so how is it configured?
5. Is there a pad between the tank and trunk?
I believe I am using a single wire connection to the gauge. I am also using a mechanical pump on the engine.
Thx, for any help
Howie
Thx, for any help
Howie
You would be well advised to consult a '68 Factory Service Manual. If you don't have one, you can access one for free at Wildaboutcars.com
In reading that manual just now, whether or not your car has a fuel return line depends on which engine it has. Cars equipped with a 350 did not, while those equipped with a 400 did. The sending units are different, too, depending on the engine.
You want section 8 of the service manual.
Thx Jaunty and pogo, I will look at the manual. Its a 350 and there is nothing on the car, frame, or pump that I can cross check with. It's a totally stripped car. Thx, I'll check in the manual.
Thx
Howie
Thx
Howie
I needed a new sending unit for my '67 Delta 88, and they're not made new for this car. I ended up using one designed for a '72 Delta 88. It was a drop-in replacement, but it had return line I did not need. I just capped it.
justintiime
June 21st, 2018 06:23 AM
dfire25
June 28th, 2016 01:37 PM
bob p
March 18th, 2015 09:51 AM
Texas442
January 30th, 2012 05:36 PM
