Fuel tank outlet
Old Oct 31, 2023 | 08:17 AM
kevdog442's Avatar
Member
Fuel tank outlet
Would anyone know if my 84 hurst/olds has a 2 or 3 outlet fuel sender in the tank? Autozoner asked me. I don’t even know what a third outlet would be.
Old Oct 31, 2023 | 08:43 AM
Look at the fuel pump on the lower passenger's side of your engine. It will either be 2 or 3 lines. FUEL OUT, FUEL RETURN and CHARCOAL CANISTER if it has a 3rd. Your fuel sending unit will be the same.
Old Oct 31, 2023 | 08:56 AM
The charcoal canister does not connect to the fuel pump. If it did, you'd be pumping liquid fuel into that canister. The pump connections are fuel inlet from the tank (a hose barb), fuel outlet to the carb (an inverted flare connection for a hard line), and a hose barb for fuel return to the tank (if so equipped).
And to the OP, every 1984 Olds 307 used fuel return and a three port pump. This is why you should never trust listings in an aftermarket catalog. The original factory P/N is 6471473. Carter M6109 and Delphi MF0006 are two available aftermarket pumps.
Old Oct 31, 2023 | 09:19 AM
DOH!
Old Oct 31, 2023 | 10:13 AM
kevdog442's Avatar
Member
Yes, I have that fuel pump with the return port and it appears that I will need the 3 outlet fuel sender because I do have a charcoal canister
thanks
Old Oct 31, 2023 | 01:20 PM
PatL's Avatar
thanks
The fuel pump has nothing to do with the charcoal canister (it just captures fumes from the gas tank to burn off, it is not attached to the fuel sender, but to vents outlets on the gas tank). Read Joe's post again, the three port fuel pump, in essence just recirculates fuel between the tank and pump and the third port goes to the carb. The fuel pump lines run back to the sender.
Old Oct 31, 2023 | 01:48 PM
69HO43's Avatar
Sender is GM part number 25001613, or you can use equivalent aftermarket.
Spectra FG08A is one aftermarket number. Shop around for the best price though. It varies greatly for the same part.
Old Oct 31, 2023 | 06:56 PM
kevdog442's Avatar
Member
Thanks guys but I think we got a little off track. I wasn’t asking about the pump, I understand that. It’s the third line on the sender ( in the tank) that I don’t know what it’s for. Usually there’s just a supply and return.
Old Nov 1, 2023 | 04:44 AM
PatL's Avatar
The fuel pump got brought into the discussion because it is a whole lot easier to look under the hood at it to determine if you have a return back to the fuel tank, which determines whether you need a one or two outlet sender.
Old Nov 1, 2023 | 06:27 AM
69HO43's Avatar
Yes. All 1984 307 Cutlass built for U.S. sales used a 3 port sender from the factory, one for the fuel supply, one for the charcoal filter vent line (which on your H/O, runs to the driver side up the frame rail, runs across the front crossmember, and then to the charcoal canister on the passenger side), and one was the little return line from the fuel pump. Two ports only had charcoal filter vent and fuel supply. But with your H/O, you don't have to worry about 2 port senders. That's why they were talking about the pump. That little return line was only used on 3-port setups so it was easy to tell which type you had just by peeking at the fuel pump without getting under the car.
Old Nov 1, 2023 | 06:46 AM
Thank you, sir for giving the correct info. I should stick to Ford trucks apparently. ☺️
Old Nov 1, 2023 | 04:02 PM
kevdog442's Avatar
Member
right but was asking about a 3 port sender.
Old Nov 1, 2023 | 04:25 PM
kevdog442's Avatar
Member
This is a new venture into “newer” cars. My 69 442 has a 2 port sender which has the return line that goes to the fuel pump. But it is obviously pre charcoal canister.
Old Nov 1, 2023 | 06:55 PM
Early cars had the vent lines routed directly from the tank and not part of the sender. Later cars incorporated the vent line into the sender. A two port sender for a 1969 DOES have fuel return. A two port sender for a 1984 does not.
navvet
Feb 11, 2015 09:33 PM
Funkwagon455
Jun 18, 2011 01:20 PM
66ninetyeightls
Ninety-Eight
Aug 23, 2010 05:43 PM
oldbill
Jun 20, 2010 02:48 AM
chris weber
Mar 19, 2008 07:51 PM
