Fuel sender
Old Mar 28, 2021 | 09:17 AM
Tanner17's Avatar
Fuel sender
I have a 1969 Cutlass Supreme convertible with a 455 big block. I need to replace the fuel sender but I don’t know which on to use.
Old Mar 28, 2021 | 09:58 AM
fleming442's Avatar
0-90 ohm. Why does it need replaced? Have you verified it bad or just throwing parts at it?
most common problems are the tank ground or a connection on either end of the front to back ribbon cable.
You should be able to ground the sender wire and make the gauge drop.
Old Mar 28, 2021 | 09:59 AM
If your question is about single vs two lines, does your car have fuel return or not? How many lines go in and out of the fuel pump?
kansjfr
Mar 15, 2021 10:45 PM
72455
Dec 10, 2020 09:36 AM
neatolds
Jul 16, 2015 05:30 PM
CaptOharry
Jun 26, 2013 10:30 AM
1973olds98
Aug 24, 2009 07:05 AM
