Fuel additives?🤔
Fuel additives?🤔
Hey all just wondering how many of you use fuel additives (fuel treatment, octane booster, etc.)
Since I've owned my '72 U code Supreme, I've only used 93 octane and it's done well, but I've been kicking around the idea of maybe some Lucas fuel treatment or maybe some octane booster to gain some performance and/or fuel mileage, but don't wanna cause any issues.
What say you?
What say you?
Agreed...so would checking the plugs be a good indicator of how well it's tuned? Because last time I checked (about 2 weeks ago) my plugs looked perfect.
Maybe it's just snake oil, but normally I run 89 in my 67 Cutlass. One day I got Lucas fuel cleaner for another vehicle and decided to throw some in the tank of my Cutlass. That fuel tank got me 17 miles per gallon, when I normally only get 11.
This VP additive is the absolute best there is. VP is the leader in racing fuels and second to none. It boosts octane rating by 10 points and 1 32 oz. can will treat 10 gallons of fuel. It's about $20 a can but if bought by the 8 count case,it's cheaper. At $2 a can it adds about $2 per gallon and is much cheaper than racing fuel.
https://proshop.summitracing.com/parts/vpr-2855
But they had higher octane gas then too. My car detonates on the best available gas and two bottles of Lucas octane booster per tank manage to keep it at bay. It doesn't improve the car's performance per se, it just allows me to run enough advance to optimize what performance the car has.
No idea...I've tried to get that info from the PO who did the work, but he doesn't remember ☹️
What say you?
What say you?
I don't think it will do much if your car is already in good working order.
I use an octane booster but my engine runs lousy without it. Engine knock/pinging/detonation, and run on, are the issues with just premium gas. My car is set at factory spec, and it requires gas that doesn't readily exist anymore. That's not the case with a factory stock 1972 Olds, and even with your rebuild and cam upgrade etc... I don't think your engine needs more than 93 octane...
Judging by your most recent threads I feel that your cars performance seems lacking to you ? Maybe lack of oomph ? Doesn't move like you think it should ?
Your setup is what may be causing that not the way your engine is running. I think you might have too much stall and possibly too little gear (3.08 rather than 3.73 ?). And it may be numbing your cars vigor on the street. Lets assume the W30 cam that's installed is the 1972 version for an automatic. An original auto 72 W30 had 2 choices for rear gear 3.42 and 3.73 and less stall than you have.
This thread https://classicoldsmobile.com/forums...ift-kit-92622/ and specifically post 7 to 12 may be of interest to you.
I'll never understand why people build their engines so that they can't even run right on pump gas. UNLESS it's purely a drag car, why build it so it'll only run right on race gas (which is like $8-10 per gallon) unless you're just super rich and don't give a ****. I like to drive my car as much as possible and still cringe a bit when I fill it up with midgrade or premium.
The engine and transmission are the "number matching" parts, and not the rearend. Changing the ring and pinion gear won't alter anything other than the gear ratio; it would be similar to changing the camshaft in the engine.
