fuel pump?
Old Oct 18, 2014 | 01:49 PM
dewcrazzy's Avatar
fuel pump?
took the 442 for a ride today and she started off running fine. Half way through the ride she felt like she was surging upon acceleration. stumbled and sounded like a cough when I took off from a stop. When I was running 45 she even felt like she was surging. Any body know where to start my trouble shooting?
Old Oct 18, 2014 | 02:03 PM
toymobile's Avatar
Check FUEL FILTER
Old Oct 18, 2014 | 02:33 PM
Tedd Thompson's Avatar
Or fuel pump.... It does sound fuel related though....Tedd
Old Oct 19, 2014 | 05:16 AM
Ozzie's Avatar
There are lots of possibilities. It does sound like it's fuel related. Do a pressure and volume check of the fuel pump at the carburetor. That should tell you if the carburetor is getting what it needs. If that's O.K. then you might want to investigate the carburetor itself. You'll have to start with the most likely items and verify each until you get to the problem.
Old Oct 19, 2014 | 06:29 AM
And don't forget the fuel hoses, which can do this if they're badly cracked (usually the first sign will be hard starting after sitting a few days) and the fuel pickup sock, which can cause similar symptoms if it's deteriorated and crud in the tank is intermittently blocking the end of the tube.
Old Oct 19, 2014 | 07:12 AM
A quick easy check on the fuel pump can be done by undoing the fuel line at the carb and putting it in to a Coke bottle unhook the coil and turn the engine over for about 8-10 seconds. If the pump is good it should fill the 16 oz bottle to about 1/2 full.Not a definitive test but will give you a idea if you have problems in that area....Tedd
Old Oct 19, 2014 | 12:51 PM
jpc647's Avatar
That's awesome advice! Sorry to hijack the thread, but I'm going to try that!
Old Oct 23, 2014 | 08:30 AM
dewcrazzy's Avatar
it ended up being the carburetor
Old Oct 23, 2014 | 09:20 AM
And... ???
Old Oct 23, 2014 | 02:30 PM
dewcrazzy's Avatar
no idea, had a back-up carb and threw it on. I will rebuild the bad one for back-up.
RenderPit
Ninety-Eight
Aug 6, 2015 04:55 PM
mefirst72
Feb 10, 2013 06:37 PM
Nor Cal Andy
Mar 29, 2012 07:27 PM
stlbluesbrother
Mar 21, 2011 03:24 PM
sshriber
Mar 22, 2010 06:16 PM
