fuel pressure regulator
Have any of you guys installed a fuel pressure regulator and gauge. I want to install one on my 69 442. Car has AC and a stock block mounted fuel pump. I don't see any good place to mount one.
If any of you have done this, I would appreciate a pic of your mount location.
I want it to look good, be accessible and functional.
Thanks for any input
I have a stock quadrajet on a very near stock 400 BBO.
Your set up is very similar to the set up I have on my 67 Camaro.
Thanks for your reply
Eric
I can't say what my fuel pressure is currently.
I have my carb off the engine for rebuild. I hope to get my carb kit from Cliff Ruggles either today or tomorrow. Then I should be able to check every thing out.
I also seemed to introduce an additional electrical issue that I will attack tomorrow and post help request in Electrical section.
Got my carb rebuilt and reinstalled today. Checked fuel Pressure @ 6 PSI so I'm not gonna be using a regulator. Tach out for clock repair so it will be a couple weeks before I can really check it out good
jensenracing77
November 18th, 2014 06:14 PM
Charlie_brown
October 30th, 2009 09:54 AM
