flickr test
So, theres another way. Just select the items you want to delete and press the delete button on your keyboard.
If you want to undo several things, use shortcut key Ctrl and Z. Each time you press Z while holding Ctrl is the same as an undo arrow. You probably already know the shortcuts for copy, cut and paste.
shamusj
March 4th, 2016 06:48 AM
