Flexplate recommendations
Old Dec 13, 2020 | 10:17 PM
dragline's Avatar
1970 Olds 442, mild upgraded 455. Is the stock flexplate ok? Any recommendations on an aftermarket flexplate? Thanks.
Old Dec 14, 2020 | 06:14 AM
cdrod's Avatar
Rodney
I didn't take chances on a 50 year old flexplate, so I purchased a Pioneer brand for a reasonable price.
Old Dec 14, 2020 | 06:35 AM
oldsmobilejim's Avatar
Inspect carefully around the bolt holes that mount the flex plate to the crankshaft and the flex plate to the torque converter. Cracks tend to start at one of the bolt holes and spread outward. Also inspect the bolt holes for elongation of the hole. If nothing found torque to specs, if shims removed with starter make sure you reinstall. It likes the engine and the engine likes it.
Old Dec 14, 2020 | 06:40 PM
Olds Performance Machine's Avatar
Stock flex plate is fine. I would trust it first over any aftermarket oem replacement.
Old Dec 14, 2020 | 08:30 PM
Its rare a flex plate cracks, usually a starter will eat the teeth first.
Prophe'c
Aug 9, 2023 08:11 AM
DYSKIE
Jun 6, 2019 02:19 AM
Gascoop
Jun 7, 2018 10:23 AM
t_huth21
Feb 27, 2015 12:41 PM
1FSTLS1
May 10, 2008 09:40 AM
