Fender tire gap
Old Sep 26, 2015 | 05:22 PM
Cutlass455's Avatar
Fender tire gap
I'm trying get it so my tire comes out more so it's almost flush with the fender so it has a wider stance. Any idea how to do so?
Old Sep 26, 2015 | 05:37 PM
svnt442's Avatar
Different wheel and tire will do the trick. You if you want the rim face to be flat, the suspensions on these cars were not designed that way so you would be looking at something a bit more invasive to try and make that happen.
Old Sep 26, 2015 | 05:41 PM
How much more do you want the wheel/tire to move outward? You can use wheel spacers.
Old Sep 26, 2015 | 06:03 PM
s i 442's Avatar
Oldsmobile enthusiast
Get some good aftermarket rims and tires and drop the 14X7 225/60 wrong size look!
A 15X7 with a 235/70 is a big tire or a 245/60/15 looks good also.
My all time favorite on anything is a 225/70 white letter tire.
Old Sep 27, 2015 | 07:58 AM
Cutlass455's Avatar
Do you have any clue what I should look for when I buy new rims and tires?cause right now I have 9 inch wide tired and wanted to go to 12, but I want the tired to come out further pretty close to the fender because right now it's set in so far. So I'm stuck on that right now
Old Sep 27, 2015 | 08:53 AM
Post some pictures of what you have now.
Old Sep 27, 2015 | 01:31 PM
svnt442's Avatar
Your best bet would be to go to a shop that does a lot of aftermarket wheels and have them do some measurements and maybe a test fit to see what you can get away with.
12" of tire is quite a bit and you need to be sure that the tire will clear not only the lip of the fender, but the inner fender as well.
Old Sep 27, 2015 | 01:33 PM
svnt442's Avatar
And what car are you working with? That make s a huge difference.
bonesbmx
Jun 2, 2020 02:10 PM
ChrisM
Mar 7, 2009 08:07 PM
The_Jeremiah
Dec 7, 2007 08:06 PM
ChrisM
Nov 1, 2007 02:23 PM
66starfire
Jan 3, 2007 10:31 AM
