Fender antenna but AM radio?
My '65 doesn't have the original radio in it but it does have the antenna on the fender. As far as I know it's original, though it has a mast with a spring on the bottom. Does this imply it had an FM radio originally? They seem quite rare on these cars and I'd be surprised if it had one.
I can not recall any car that came OEM with a spring at the base of the antenna. I concur that it is an aftermarket antenna. The spring is there to keep you from bending the antenna, and no other reason. There are antennas with coils and such on them, but that is for tuning CB radios, because they need specific effective length antennas to transmit.
I should've clarified- I know the spring mast isn't original but I'm wondering if the presence of an antenna itself on the car is original. Reason I ask is as far as I know usually AM car radios use an internal antenna (inside the radio). Did the AM radios in these use an antenna outside the car?
Any GM car from the '60's or earlier with radio will have an outside antenna. By the '70's windshield antenna became the most common GM antenna. I think the 69 Pontiac Grand Prix was the 1st with windshield antenna.
Henry
Henry
billleft
January 17th, 2014 05:31 PM
